Whale water fitting
Sep 27, 2020
41
Hi all does the whale water fitting clip into anything or just push in I'm asking this as I have just purchased a floe drain down kit tried to add pressure and I won't hold it just pops the connector off ??
May 2, 2020
279
111
4,735
Hi
With an onboard pump which are usually a diaphram pump you need to pressurise the system after the pump not from the outside
Sep 27, 2020
41
I noticed a big black cylinder with a tyre valve fitted to it after the pump is this what you are referring to ?
May 2, 2020
279
111
4,735
It could be but not knowing what your caravan is or seeing the cylinder its impossible to say for definite, I made my own on our van
Jan 19, 2002
1,711
551
The whale square is a push fit, although to my recollection it is partly held in place by closing the external lid towards the top.
Mar 27, 2011
1,332
507
The lid when closed holds it in place, you can see a hook sort of thing at the top of the lid and you’ll see where it catches into the whale block
Jan 9, 2018
31
34
10,535
Hi @Leemallin
My name is Hayley and I work in the marketing team at Whale.
Please feel free to contact our Customer Service Team who will do all they can to assist you with your query. You can call them on 0345 9090 911 or email info@whalepumps.com.
Alternatively, please privately send me the best number to get you on and I will get one of our team to give you a call.
Best wishes,
Hayley
