When i connect my whale pump to van it leaks when in use i have bought the service kit and i chanced both conector seals but still leaking the van is a pressurized system any ideas please Mark
Hi James no i dont think so its when you connect pump to van i have changed both o rings. I dont know if it is the pipe to pump leaking or the unit attached to van, it trickles out when running hot or cold thanks mark
