Bought my Ace Firestar back in October 08,had a few niggles which were put right by the dealer within 2 weeks.
One of the problems was every time we towed the van the front of the Truma gas fire jumped off its fixings which to us was not satisfactory, my dealer said no problem they no about the problem we just put a screw in the centre to hold it in place.
I was bit sceptical but thought well it will fix the problem, sure enough no problems from that time on.
Today went through checking all the systems before we go for a long weekend in a couple of weeks time, came to check the Truma on gas no ignition, manual says on automatic ignition check the battery, yep what a performance to change the battery, remove the screw between the vents at the top, release the springs and remove the front, replace battery so good so far.
Now reassemble, all ok until you need to replace the dam screw the dealer fitted, good job l was an engineer with a magnetic Phillips long reach screw driver, even so took all of 40 minute s to change a bloody battery, you may say nit picking but imagine if this was when you had just got to site with the darkness approaching no fun l can assure you, Truma have been making fires for the caravan industry for years why o why can't they place the battery within easy reach, rant over
