I assume 602 was talking UK van with UK plate. A good old trusty GB sticker should alert even the dopiest of German Plods to the outfit being British
Right hand drive and British number plates should even give them another clue if they are really thick or having a bad day
If you make up a very clear and visible plate as some case of misfortune has caused the loss of the genuine plate do we assume that we will be hassled by police across europe for trying to make up for the loss?
Simple answers
Weigh yourself down with a spare plate!
Fix the plate on with large stainless bolts through the rear panel of the caravan using nyloc nuts or locking nuts! (no help, bolts rusting and the plate flying off)
Have an old fashioned non BS (No one will notice really) adhesive reflective yellow plate under the normal plate and carry sticky numbers & letters just in case!
I just can't take this seriously.
What do yo do when anything goes wrong? For God's sake, you make do, compromise or use your iniative to make the best if a bad job and I believe most police will be pleased to let you travel as long as you are not up to no good.
ie. you've stolen the van.
Or may be you could abandon the van at the road side rather than drive on without a regular plate, then track down a UK plate or get one via express courier from the UK. No doubt the van would still be where you left it a day or two later
