- Mar 14, 2005
- 19,085
- 4,290
- 50,935
In another thread you have posted a question:
I have copied it and created a new thread, to avoid futher pollution of a thread that Parksey has commented on.
I note from your post that you have experienced caravanning before, so you are not new to it, and hopefully you will have gained some experience and wold be able to spot the some of teh early signs of when an outfit may be about to become unstable.
With that in mind your choice of car and caravan on paper looks OK, and has a towing ratio of 97% which is inline with the industry advice.
I would make two comments though. The first is about safety. No one can tell you whether your proposed outfit is "safe" Safety is far more about driving style and habits that any weight ratio. It is vitally important that both the car and the caravan are properly maintained and the correct tyre pressures etc are set. Loading is important and ill offer some views on that in the next paragraph, but the single most important factor that affects safety is speed. Every outfit is stable when stationary, its only when the speed is increased that the chances of instability also increase. If you begin to detect instability slow down, .and at the earliest safe opportunity pull over and reassess your loading.
With regards to loading, its important to keep moments of inertia to a minimum - that's engineering for keeping heavy items low down and as near the axle of the caravan as possible, however yo do need to create some nose load, and that is generated by having the caravan loaded so its always pushes it nose down. How much nose load is also not a specifically definable figure, but you must be mindful of the mechanical limits for the noseload set by both the car and the caravan manufacturer. IF there is a difference between the car and caravans specification for nose load always use the lower figure as your absolute limit. It isn't always necessary to use the scope of a nose load limit but it is proven that more is better than less.
The more I read the more I get confused concerning a safe weight...
I know that my
kerb weight 1,810kg
tow 1,500kg
Nose on Hitch 75kg
I'm buying an Elddis affinity 540. unladen 1298kg
MTPLM 1450kg
So assuming the max weight for the caravan is less than my cars towing weight, I'm pretty safe with the towing.
So on a quick calculations and a simple theory, so if I keep my caravan weight within its limits, and ensure than the nose weight is 75kg.. I'm towing safely
My tow car is an Mitabishi outlander PHEV, Which on demo's it's towing a 17ft Swift Sprite which is slightly heavier than the Elddis.
It used to tow my old Elddis Avante 520 without problems.
