What towbar?
I always thought a towbar was a towbar but now I find that there are different types/specs and different electrics too.
I need to equip my 2005 Jaguar 2.0 diesel X-Type with a towbar and electric system in order to tow a 14' Burstner single axle van with a 13 pin electric system (no battery)
Can anyone help me with what I should be looking for please, or alternatively recommend a dealer/fitter (near Heathrow airport) that will sort me out without taking advantage of my ignorance.
There are basically 3 types of towbar.
1. Fixed Flange
2. Fixed Swan Neck
3. Removable .
It depends whether or not you want the towbar permanently on show or not.
The two fixed types are on show all the time but with the fixed flange type you will need the Al-Ko extended neck towball, not the standard towball usually supplied.
The removable one you stow in the car when not in use so keeps the back end of the car clear
The electrics will have to be fitted to a 13 pin socket via a car specific wiring loom which should all be part of the fitting service but make sure it is fully wired to include the fridge supply and battery charging circuits, even though you may not use the battery charging bit on this van but may need it in future.
The electric socket stays on the car , usually pretty inconspicuously under the rear of the car.
With each type you must make sure the towball is completely clean of all paint or protective coating and keep it that way.
Given that your model of Jag is basically a Mondeo with a different body it should not cost a fortune to fit. However do be aware that around that time the maximum noseweight on some Mondeos was 75Kg so take care to make sure you know what the limit is on the Jag - and that is the lower of the towbar limit or the car chassis limit.
Thanks for the replies.
Given that I'm not too clever at bending down, would I be best served with a Flange type with the electrics mounted on a plate to the side rather than a Swan neck where (I believe) the electrics are mounted under the bumper?
Also, as this is now an old car and there are no warranty considerations, would bypass electrics suffice or must I pay for vehicle specific? (I am trying to keep the cost as reasonable as possible within the bounds of safety and suitability.)
To keep the rear of the car neat, the receiver for the detachable types is mounted inside the rear bumper plastic cover, so this where the 13 pin socket resides too. There is generally only room for one socket ie a 13 pin. Access to both may be through a removable hatch in the bumper, which sometimes has a cut line for this scribed or moulded on the inside of the bumper. This means access is limited and can be awkward - you might have to use a kneeling pad, so this may not be suitable for you.
The flange type usually traps a plate between the towball and the flange which will carry the socket (or 2 old style ones). Being outside the bumper, this will probably be an easier option for you. People will keep clear of in car parks as this type can do of lot of damage to their cars!
Whether you go for factory or aftermarket electrics, both are going to connect to the cars existing electrics as far as road lights are concerned. Factory systems rarely seem to accomodate our need for fridge wiring, so this has to be added in who ever installs it. The one advantage of factory is that you can be sure its all going to integrate with your car, as there will probably be a module that recognises the trailer attachment and do a few clever things. Many cars already have a small socket for road lights hidden in the boot, ready for factory trailer wiring when required.
The chap across the road from bought his first caravan yesterday a 2 berth 2016 Swift , but he said the salesman said he would need a swan neck tow bar fitted to his Mondeo estate, why a Swan neck, any ideas why,
It will have an Al-Ko friction stabiliser head on the hitch which needs extra spacing from the bumper. On a fixed bar you can fit a special ball that has extra standoff but with a removeable a so-called swan neck is often the only option.
Witter supply 4 options.
Fixed Flange
Detachable flange
Fixed swan
Detachable swan.
Only the first two require an Alko bolt on ball.
I have bypass electrics and detachable swan neck, however next time it will just be a fixed swan.
You do have to bend down however, and a caravan mover is ideal to save bumper damage.
So i would say a fixed flange with bumper plate along with bypass electrics would be fine.
https://www.pfjones.co.uk/tow-bar-types-explained.html
Thank you pf, that was what I was inclining towards. I will just confirm that the X-type has no hidden problems with bypass electrics before I go ahead and seek quotes.
Well the clue is in the name - the bypass unit is used to bypass the cars bulb failure module, which might otherwise be confused when the caravan road lights are added to the cars own load. This is one of the functions of a factory module, which may also turn off the cars foglights, reverse lights and brake lights, to avoid reflected glare from the van at night. In addition factory modules may turn off the rear parking sensors when reverse is engaged with the van on, which can be very annoying indeed. Its very unlikely that aftermarket will have these functions
xtrailman said:
Rear parking sensors on my car can be turned off with a dash switch.
That's true, then can, but I would guess they re-activate as soon as you select reverse again, since you wouldn't want to forget they are off if you are used to having them on. This is how mine operate.
Strange, my Passat has both front an reversing sensors and they never activate if the van is hitched up but if someone walks near them with the van hitched they start shouting.
Hey Guys,
I had the same issues with the parking sensors when I had someone come to fit the towbar onto my Ford Mondeo.
I agree, its not often that you reverse with your van still attached :lol: but if you've got parking sensors you may as well have them working right?
Anyway, I managed to find a local garage on Towbar Fitting that could reset the electronics on my car and since then they have worked fine.
People recommend going back to your dealer when you have a towbar fitted but I managed to find a cheaper solution so it may be worth checking out,
Hope this helped guys. 🙂
CampingTom said:
Hey Guys,
Hello Tom,
When I contract someone to do a job like fitting a towbar, I expect then to do it right . So if it does not work the fitters have failed to do the job properly. So why should I go and spend more money elsewhere to have the job the fitter should have done, put right?
Sadly its this attitude we seem to have in GB, that we expect jobs to go wrong so we are prepared to put up with shoddy work. I always chalance shoddy work, and usually it gets put right, becasue that what I paid for. On the odd occasion where for whatever reason its beyond the original workmans capability, I arrange to have it put right but the original contractor foots the bill.
My rear sensors can be deactivated before reversing and reactivate when you go back into drive, as for how often do you reverse with the caravan , everytime out, not lucky enough to get a drive into place, pitch.
yeezy boost 350
jerseys cheap
coach outlet online
heat jerseys
phillies jerseys
cowboys jerseys
hermes bags
discount nike shoes
oakley sunglasses outlet
michael kors outlet store
louis vuitton bags
yeezy boost
mont blanc pen
michael kors outlet
adidas uk
birkenstock outlet
louboutin pas cher
nike outlet
toms
burberry outlet online
kate spade handbags
purs jerseys
adidas outlet store
cheap jerseys
toms
coach factory outlet online
cheap nike sneakers
nfl jerseys
louboutin outlet
longchamps
air max outlet
ralph lauren sale
adidas running shoes
coach handbags outlet
birkenstock shoes
coach outlet online
true religion
pandora charms
fitflop shoes
nike outlet store
ralph lauren outlet
adidas nmd r1
yeezy shoes
air max
nike outlet store
coach outlet online
michael kors
coach outlet store online clearance
hermes bag
kate spade bags
moncler uk
versace
cheap jordans for sale
prada outlet online
ralph lauren outlet online
louis vuitton factory outlet
gucci borse
mont blanc pen
swarovski sale
coach outlet online
kate spade outlet online
mulberry uk
coach purses
jordans
tory burch outlet online
adidas outlet online
giants jerseys
adidas nmd runner
gucci outlet online
adidas nmd runner
adidas outlet store
yeezy boost 350
beats by dre
rolex replica watches
nike outlet
moncler uk
gucci handbags outlet
ralph lauren sale
coach outlet store
kd shoes
cheap jordan shoes
polo ralph lauren outlet online
sac longchamp
burberry outlet store
ralph lauren outlet
kate spade outlet store
harden shoes
pandora jewelry
pandora charms sale clearance
michael kors handbags outlet
polo ralph lauren
christian louboutin
dansko outlet
texans jerseys
ralph lauren sale
fitflops
fendi bags
air max 90
dodgers jerseys
eltics jerseys
louis vuitton outlet online
longchamp bag
rolex replica watches for sale
chaussures louboutin
nike free 4.0 flyknit
rolex watches
coach outlet store
yankees jerseys
montblanc
pandora charms
fitflops sale clearance
pandora
coach outlet online
nike free run flyknit
nfl jerseys cheap
curry shoes
ray ban sunglasses outlet
christian louboutin outlet
adidas nmd runner
nike air max 95
marc jacobs
christian louboutin shoes
adidas ultra boost
ray ban sunglasses discount
cheap jordan shoes
adidas superstars
hermes outlet online
oakley sunglasses on sale
cardinals jerseys
michael kors outlet clearance
abercrombie outlet
marc jacobs outlet
hermes outlet
cheap rolex watches
pandora charms
air max 90
nike free run
nike outlet store online
longchamp handbags
yeezy boost
true religion jeans
ralph lauren sale
tory burch sale
coach outlet online
fitflops clearance
air max
cheap jordan shoes
michael kors outlet online
nike sneakers
coach outlet online
yeezy boost 350
louboutin outlet
coach outlet online
gucci outlet online
air jordans
coach outlet store
discount oakley sunglasses
moncler pas cher
polo ralph lauren
mulberry bags
sac louis vuitton pas cher
coach outlet online
ray bans
michael kors bags
adidas
toms outlet
coach outlet store
michael kors
mont blanc pens
broncos jerseys
sac louis vuitton
birkin handbags
swarovski uk
fake rolex watches
clarks shoes outlet
wireless beats headphones
salomon boots
birkenstock outlet
ralph lauren
jordan shoes
fit flops
coach outlet store
louis vuitton outlet store
adidas nmd r1
gucci
red bottom shoes for women
mulberry handbags
adidas nmd r1
christian louboutin sale
swarovski crystals
ralph lauren outlet
rangers jerseys
mulberry outlet uk
mlb jerseys
true religion jeans outlet
pandora jewelry outlet
fitflops clearance
beats wireless headphones
burberry sale
bercrombie
tods outlet
fitflop shoes
cheap nike shoes
cheap nfl jerseys
kd 8 shoes
salomon outlet
nike outlet online
burberry outlet
michael kors bags
jimmy choo shoes
ed hardy store
fred perry polo shirts
cheap oakley sunglasses
valentino outlet
pandora charms outlet
air max shoes
nike store
dolce and gabbana outlet online
yeezy boost
toms outlet
fitflops sale
michael kors outlet canada
nike roshe one
gucci
49ers jerseys
moncler jackets
mbt
michael kors
ralph lauren outlet
adidas
yeezy boost 350
nike air max
yeezy 350 boost
michael kors bags
ralph lauren
patriots jerseys
adidas nmd r1
michael kors uk
coach outlet online
nike blazer low pas cher
pandora bracelet
nike air max 95
red sox jerseys
gucci bags
coach outlet online
air jordan shoes
nike flyknit
christian louboutin
mulberry uk
moncler outlet online
levis outlet
toms
nike roshe shoes
longchamp soldes
longchamp outlet store
hollister clothing
coach outlet canada
lakers jerseys
kate spade uk
longchamp bags
michael kors
ralph lauren sale clearance uk
moncler jackets
chi flat iron
jordan shoes
hermes bags
polo ralph lauren
mulberry
ralph lauren
clarks shoes outlet
coach outlet online
nfl jerseys
coach outlet
michael kors
mlb jerseys
adidas sneakers
longchamp bags
adidas store
hollister kids
beats headphones
nike cortez classic
tigers jerseys
warriors jerseys
pandora jewelry
salomon outlet
cheap air jordans
longchamp pliage
nike air force
michael kors outlet
louis vuitton purses
michael kors
nfl jerseys wholesale
adidas superstars
packers jerseys
longchamp handbags
fitflops sale
michael kors
red bottom
pandora outlet
white sox jerseys
fitflops sale
mbt
air max
clarks
nmd adidas
cheap ray ban sunglasses
coach outlet online
adidas yeezy boost 350
burberry outlet
cavaliers jerseys
air jordans
adidas sneakers
true religion outlet online
fred perry shirts
adidas trainers
polo ralph lauren pas cher
cheap jordan shoes
pandora jewelry store
red bottom heels
eahawks jerseys
ed hardy outlet
coach outlet online
louboutin shoes
nike uk
clarks shoes for women
parada bags
longchamp sale
yeezy shoes
bulls jerseys
moncler coats
nike outlet store
vans outlet
vans store
timberland boots outle
ray ban glasses
christian louboutin pas cher
cheap jordan shoes
rolex watches
jordan retro
yeezy boost
oakley sunglasses wholesale
nike tn pas cher
jordan femmes pas cher
rockets jerseys
cheap rolex replica watches
adidas nmd runner
montblanc pens
coach outlet online
gucci bags
birkenstock uk
adidas yeezy boost
thunder jerseys
jordan uk
louboutin outlet
birkenstocks
sac longchamp
ghd straighteners sale
adidas yeezy boost
coach outlet online
fitflop
adidas yeezy boost
birkenstock
celine outlet online
air max 90
fitflop
birkenstock outlet
ed hardy clothing
nike sneakers
fit flops
louboutin shoes
ray ban sunglasses cheap
ed hardy uk
adidas trainers
ralph lauren
chaussure louboutin pas cher
ghd hair
nike air huarache
ray bans
yeezy boost 350 v2
ray ban glasses
coach outlet online
coach factory outlet store
adidas superstar trainers
michael kors
polo ralph lauren
adidas superstar shoes
mlb jerseys whgolesale
pandora charms sale
tods shoes
birkenstocks
celine handbags
yeezy shoes
red bottom
kate spade outlet
kate spade bags
mbt
fitflops sandals
mlb jerseys
coach outlet online
cheap air max
longchamp bags
dansko
adidas sneakers
michael kors uk
adidas yeezy boost
cubs jerseys
ralph lauren uk
coach outlet online
fit flops
louboutin outlet
kate spade purses
pandora charms sale
fref3rtg
