what towing car ?
8,483
MichaelE said:
Whilst MTPLM is a useful figure to use when matching car to its caravan its not absolute, in as Prof says axle loads are the key legal figure. Many makers artificially keep MTPLM low in order to attract buyers of new caravans who may have lower kerb weight cars. The penalty is that payload is compromised. Whilst in fact for some vans the MTPLM can be subsequently raised by the caravan maker for a small fee. Look at Baileys Pursuit 430/4 which can have its MTPLM increased to 1300kg a 70KG+ increase. Similarly several other in Baileys range too. There are no physical change to the chassis/axle as the margins are already built in.
You are referring to the caravan , but the issue is the cars maximum tow weight , surely you dont want to plate the caravan to make it heavier?
Not really sure what you mean. Replating to increase the MTPLM doesn't increase the weight of the caravan.
1,818
Re plating the caravan will not make it heavier it just gives you a better margin when loading. The only downside I can see is it might just put some people off when it comes to selling it as it might then appear potentially too heavy for their car. I doubt it would make any real difference to the selling price in practice though.
4,132
Hello Michael,
I'm sorry but you clutching at straws on this one.
The trailers MTPLM is a limit, not a weight, an important difference. Also the MTPLM includes the nose load, which does not form part of the towed load.
The nose load is not forgotten, its carried by the tow vehicle, and so it must be considered as part of the cars axle loads.
I have frequently explained that the nose load of twin axle is a particularly sensitive issue and it changes aggressively if the height of the hitch is different to its working height.
Now to this old chestnut of the invalid insurance. When you take out standard car insurance the policy is issued ob the basis of the cars standard specifications including the cars maximum towed weight limit. If the insurance company wants to apply different limitations, they MUST be included in the terms and conditions when the policy is taken out. They cannot apply new limitations such as the one you describe after the fact.
There are two circumstances where such an out come might arise and be miss reported, firstly if the vehicles permitted towed weight was less than the cars ulw, or if the driver only had a Cat B (not BE) which limits the driver to trailers where the MTPLM must not exceed the car ULW. In both cases the driver would have been driving illegally and thus without insurance.
My point was why replate your caravan so you can carry more and yet your car is on the limit already?
Clutching at straws ? I fully respect your opinion!
4,132
Hello Michael,
In respect of this thread, neither the OP nor Kwaked has suggested replating, that was your interpretation.
As for the rhetorical question that Kwaked asked several posts ago about the legality of running 100kg over the tow cars maximum towed weight limit, sadly that is strictly a no no, and if you are caught then there could be several charges that could be brought, the first is overloaded vehicle, they could also check the axle loads and if the axle is also overloaded they could also add that as a charge. If the outfit was brought to the authorities attention as the result of some incident, they could also add dangerous driving. and unsafe vehicle. Also your insurance would be invalidated if you are overloaded.
Its not worth the risk, as each if those offences would carry points, and some can in the worst cases also carry prison sentences.
In terms of if its detectable, purely on the points of actual weights vs limits, to prosecute the authorities would have to weigh the outfit. As some weighbridges have a certificated accuracy of +/-10kg and most +/-20kg thus an 100kg overload would be measurable.
Would the DVSA prosecute? well that is not certain. If they suspected it were a genuine mistake, they would probably detain the vehicle until you could remove enough payload to bring it back into range, You might get away with a caution. If on the other hand they suspect it should have been detected by the driver before the journey started or it was a deliberate action they could choose to prosecute.
Sorry Prof but I never suggested or interpreted to have the caravan replated ?
I simply replied to another poster who said it could be done
I simply asked why you would want to be able to carry a bigger payload when you are on the limit already
1,818
The point about insurance is not simple. The fact that a car was towing a trailer in excess of its maximum weight would not automatically invalidate the policy. Under current regulations the insurer would have to show it was a contributory factor. A serious snake on the motorway might allow the insurer to repudiate but pulling out of a side road when something was coming should not.
I do also wonder about prosecutions for overloading if you exceed the MTPLM but the caravan could be uprated to that figure or more without any alteration. On that basis there must be an argument that the actual maximum was not exceeded and the caravan was not overweight but simply exceeded an artificial figure used by the caravan builder to sell more caravans.
4,132
Hello Ray,
The second point you made in your last post has made me reexamine the issue of MTPLM vs MAM vs Axle Limits for trailers. The implications and consequences are different depending on what approach you make to subject.
Legally the assessment of over loading (as different to other load related offences) is determined by measuring the load in question and comparing it to the stipulated limits. The only grey bit is the calibration of the measurement device and the tolerance required to to remove all uncertainty. Once any measurement error is removed the matter is very black and white.
But your point is what is the limit? Regardless of what can be done by the manufacturer to upgrade the MTPLM, unless that process has been undertaken, the limit is what the caravan is registered as having at the date of the alleged offence.
It long been a practice to have goods vehicles down plated where they are transporting bulky low density products. To get a vehicle suitable for the volume means purchasing a vehicle of the next weight rating and then getting down plated. Mechanically its quite capable of carrying more than its plated weight, but if it is stopped and found to be loaded above its plate, the offence is overloading based on its plated weight not its mechanical capability.
The offence of overloading is different to having a dangerous load. A dangerous load is more difficult for the crown to prove, and whilst overloading could result in a dangerous load, its important to understand that sometimes a dangerous load does not have to mean a vehicle is over loaded.
For drivers with only CAT B licences there are other pitfalls. Consider a Cat B driver purchasing a secondhand caravan, where the basic specification states the MTPLM which is just below their tow vehicles ULW, but then the previous owner of the caravan had the MTPLM increased which takes it over the tow vehicles ULW, the new owners licence would be invalid.
How insurance companies accept liability or otherwise will depend on the individual case. For example if there as a provable case of deliberate overloading, I suspect the insurance company would seek redress from the policy holder, If the incident was accidental, then the insure may take a more lenient view.
May 24, 2014
3,687
765
Initially we looked at Shoguns, but i struggled to find a good one to be honest.
8 out of 10 had really bad rust problems (over the rear wheel arch specifically) others had diffs on the way out,
I would try looking in a dealership rather than a scrap yard. B)
Shoguns have a reputation for rock solid reliability abd being as tough as nails. Im not saying this because I have one, I bought one for that reason. Actually had two. Not as smooth as your BMWs etc, but these are workhorses, not Chelsea chariots with a strange accent. Fantastic commanding driving position, all the bells and whistles you could want. Large carrying capacity, 7 seats, go anywhere, pull ANY van all day long.
Also had xTrails and a Volvo XC70 and would recommend those too.
4,941
Unless I use quotes, All advice and opinions
Read more at http://www.practicalcaravan.com/forum/towcars/53900-what-
towing-car#3bK7PAdvU36K7rpX.99
Hi Prof.
In real world time I think you will find no UK insurer has ever repudiated policy liability on the basis you state
4,132
Hi Prof.
Hello Dusty,
I don’t know if they have or not, but I have absolutely no doubt that they could if they chose too.
The basis of my position is that a policy is issued if both the proposer and the insurance company agree the terms and conditions of the policy. That is the contract. It is not expressly defined but based on the proposer’s stated vehicle make and model, the insure will draw the details of that vehicle from their databases in its standard configuration, and will use that information in the generation of the policy.
I believe that all motor policies now require the policyholder to inform the insurer of any material changes made to the motor vehicle that might affect the insurers risk assessment. The insurer reserves the right to review the risks and to amend their policy offer accordingly and that can include withdrawing a policy or refusing to offer a policy, and many shades in between including special conditions. Effectively the Insurer holds all the cards.
It is part of every motor policy; that the policyholder is responsible for ensuring the vehicle is roadworthy, and that the policyholder will abide by all legal driving requirements.
One of those legal requirements is that the vehicle must be operated in a safe manner.
By definition overloading is unsafe, and if that action can be shown to be deliberate the insurer can legitimately point out that the vehicle was knowingly being operated outside of the cover provided by the policy. As a consequence an insurance company could seek redress for any monies paid out as part of a claim from the policyholder.
In addition they could also deem that claim to have been fraudulent, and as such declare the policy VOID and blackmark the policyholder on the insurers database.
1,818
Overloading could only be a reason for the insurer to turn the claim down if it was a cause of the accident and after one has occurred that could be difficult to prove. If it was not the cause of the accident but the insurer became aware of it though they might increase the premium at renewal on the basis you were a worse risk than that you declared.
Overloading cannot be fraud though as there is no way off showing that the policyholder was trying to gain any advantage through their actions. Fraud is where you try to get a reduced premium by deliberately telling a lie to get the insurance or a reduced premium.
It is correct though that if they are able to turn down the claim they can look to the policyholder to recover any payments made to third parties and that can be very substantial.
4,132
Raywood said:
Overloading cannot be fraud though as there is no way off showing that the policyholder was trying to gain any advantage through their actions. Fraud is where you try to get a reduced premium by deliberately telling a lie to get the insurance or a reduced premium...
Ray
I never suggested that overloading is fraud, but attempting to make a claim if you were knowingly overload is.
1,818
ProfJohnL said:
Ray
To be frank I have never met a claim where that has been established, even with commercial vehicles, where overloading can be a problem. It would be extremely difficult to prove knowledge, unless you admit it, and even then I am doubtful it would be regarded as fraud, although it might be grounds to turn down a claim if it was a cause of an accident.
4,132
Hello Ray,
I don't want to make this crusade, but what I have written is I believe technically correct, Whether insurance companies choose to pursue or not is up to them.
What I am certain of is that some drivers be overloaded, some will be unintentional, but I am also certain that some will be knowingly or even deliberately overloaded.
4,219
I'm with the Prof, a neigbour of mine, brings the caravan back to to the house on a Thursday, loads bikes microwave, bedding, bbq, chairs and awnwning. And almost everything else.. " Oh were are only going 60 miles to the site. " wel over loaded. OUCH.
4,941
Looks are not every thing Hutch. He could be ok!?
On the Prof's Insurance point does anyone know of any one case where a claim has been rejected??
Even if it were the drivers Insurer under the MIB Rules will become the Insurer concerned and still have to deal with the claim . And yes they can seek redress from the policy holder. In practice it is highly unlikely due to potential "man of straw" syndrome and of course undisputable evidence of overloading. Ever seen a smashed up caravan :p
Sep 5, 2016
239
After my recent run in with the regeneration of my DPF I would suggest to anyone buying a new or second hand diesel vehicle towing car to negotiate a warranty on the DPF because it is not covered by the vehicles warranty, in a lot of cases people are taking brand new vehicles back to dealerships with a DPF problem, and it is the same question they ask have you been doing short runs and going to the shops, this problem is not just related to make of vehicle, this problem is well reported inn the media when you start to do a search on the subject,
1,818
If you own your own home then you may be worth more than you realise. Just how far a company will chase you depends on their internal policies but they will look at the situation. If the house is jointly owned they might not be able to sell it from under you but they could put a charge on it so they can get their share plus interest when it is sold.
For people in work they can get an attachment of earnings order to get at a portion of your pay.
Jan 24, 2015
187
That depends on what the insurer thinks they are insuring. We have had to declare the towbar as a modification, which is recorded on the policy, and the fuel chip is recorded but not as a modification as it's not permanent.
My point here is that the insurers will always seek to reduce their payout and use things lke undeclared modifications to do so.
Yes ..... especially in my line of work!!
1,818
The Ombudsman will only allow breaches of policy conditions to be allowed to avoid the claim if it is relevant. That would mean overloading would have to be proved, not easy after an accident and be a factor in the accident. On that basis I doubt anyone will know of a case and I certainly have not met the problem.
Non declaration of a material fact in assessing the premium could be grounds for avoiding the policy altogether if the truth would have increased the premium but under current rules the insurer has to have asked and the answer be wrong. As almost all companies accept tow bars at normal rates suggesting this would be grounds for increasing the premium would be an uphill struggle for an insurer but it is not worth the risk. If an insurer does increase the premium for a tow bar go elsewhere as they are having you on.
4,132
An incident involving a motor claims does not have to be a crash or the loss of integrity of the car and trailer ( if its towing one). Under those conditions the state of load would be perfectly detectable.
1,818
Not sure what you are looking at the other main source of claims is theft which would prevent the insurer weighing it although they might query a claim if the contents claimed for were too heavy.
Jun 2, 2017
141
yeezy boost 350
jerseys cheap
coach outlet online
heat jerseys
phillies jerseys
cowboys jerseys
hermes bags
discount nike shoes
oakley sunglasses outlet
michael kors outlet store
louis vuitton bags
yeezy boost
mont blanc pen
michael kors outlet
adidas uk
birkenstock outlet
louboutin pas cher
nike outlet
toms
burberry outlet online
kate spade handbags
purs jerseys
adidas outlet store
cheap jerseys
toms
coach factory outlet online
cheap nike sneakers
nfl jerseys
louboutin outlet
longchamps
air max outlet
ralph lauren sale
adidas running shoes
coach handbags outlet
birkenstock shoes
coach outlet online
true religion
pandora charms
fitflop shoes
nike outlet store
ralph lauren outlet
adidas nmd r1
yeezy shoes
air max
nike outlet store
coach outlet online
michael kors
coach outlet store online clearance
hermes bag
kate spade bags
moncler uk
versace
cheap jordans for sale
prada outlet online
ralph lauren outlet online
louis vuitton factory outlet
gucci borse
mont blanc pen
swarovski sale
coach outlet online
kate spade outlet online
mulberry uk
coach purses
jordans
tory burch outlet online
adidas outlet online
giants jerseys
adidas nmd runner
gucci outlet online
adidas nmd runner
adidas outlet store
yeezy boost 350
beats by dre
rolex replica watches
nike outlet
moncler uk
gucci handbags outlet
ralph lauren sale
coach outlet store
kd shoes
cheap jordan shoes
polo ralph lauren outlet online
sac longchamp
burberry outlet store
ralph lauren outlet
kate spade outlet store
harden shoes
pandora jewelry
pandora charms sale clearance
michael kors handbags outlet
polo ralph lauren
christian louboutin
dansko outlet
texans jerseys
ralph lauren sale
fitflops
fendi bags
air max 90
dodgers jerseys
eltics jerseys
louis vuitton outlet online
longchamp bag
rolex replica watches for sale
chaussures louboutin
nike free 4.0 flyknit
rolex watches
coach outlet store
yankees jerseys
montblanc
pandora charms
fitflops sale clearance
pandora
coach outlet online
nike free run flyknit
nfl jerseys cheap
curry shoes
ray ban sunglasses outlet
christian louboutin outlet
adidas nmd runner
nike air max 95
marc jacobs
christian louboutin shoes
adidas ultra boost
ray ban sunglasses discount
cheap jordan shoes
adidas superstars
hermes outlet online
oakley sunglasses on sale
cardinals jerseys
michael kors outlet clearance
abercrombie outlet
marc jacobs outlet
hermes outlet
cheap rolex watches
pandora charms
air max 90
nike free run
nike outlet store online
longchamp handbags
yeezy boost
true religion jeans
ralph lauren sale
tory burch sale
coach outlet online
fitflops clearance
air max
cheap jordan shoes
michael kors outlet online
nike sneakers
coach outlet online
yeezy boost 350
louboutin outlet
coach outlet online
gucci outlet online
air jordans
coach outlet store
discount oakley sunglasses
moncler pas cher
polo ralph lauren
mulberry bags
sac louis vuitton pas cher
coach outlet online
ray bans
michael kors bags
adidas
toms outlet
coach outlet store
michael kors
mont blanc pens
broncos jerseys
sac louis vuitton
birkin handbags
swarovski uk
fake rolex watches
clarks shoes outlet
wireless beats headphones
salomon boots
birkenstock outlet
ralph lauren
jordan shoes
fit flops
coach outlet store
louis vuitton outlet store
adidas nmd r1
gucci
red bottom shoes for women
mulberry handbags
adidas nmd r1
christian louboutin sale
swarovski crystals
ralph lauren outlet
rangers jerseys
mulberry outlet uk
mlb jerseys
true religion jeans outlet
pandora jewelry outlet
fitflops clearance
beats wireless headphones
burberry sale
bercrombie
tods outlet
fitflop shoes
cheap nike shoes
cheap nfl jerseys
kd 8 shoes
salomon outlet
nike outlet online
burberry outlet
michael kors bags
jimmy choo shoes
ed hardy store
fred perry polo shirts
cheap oakley sunglasses
valentino outlet
pandora charms outlet
air max shoes
nike store
dolce and gabbana outlet online
yeezy boost
toms outlet
fitflops sale
michael kors outlet canada
nike roshe one
gucci
49ers jerseys
moncler jackets
mbt
michael kors
ralph lauren outlet
adidas
yeezy boost 350
nike air max
yeezy 350 boost
michael kors bags
ralph lauren
patriots jerseys
adidas nmd r1
michael kors uk
coach outlet online
nike blazer low pas cher
pandora bracelet
nike air max 95
red sox jerseys
gucci bags
coach outlet online
air jordan shoes
nike flyknit
christian louboutin
mulberry uk
moncler outlet online
levis outlet
toms
nike roshe shoes
longchamp soldes
longchamp outlet store
hollister clothing
coach outlet canada
lakers jerseys
kate spade uk
longchamp bags
michael kors
ralph lauren sale clearance uk
moncler jackets
chi flat iron
jordan shoes
hermes bags
polo ralph lauren
mulberry
ralph lauren
clarks shoes outlet
coach outlet online
nfl jerseys
coach outlet
michael kors
mlb jerseys
adidas sneakers
longchamp bags
adidas store
hollister kids
beats headphones
nike cortez classic
tigers jerseys
warriors jerseys
pandora jewelry
salomon outlet
cheap air jordans
longchamp pliage
nike air force
michael kors outlet
louis vuitton purses
michael kors
nfl jerseys wholesale
adidas superstars
packers jerseys
longchamp handbags
fitflops sale
michael kors
red bottom
pandora outlet
white sox jerseys
fitflops sale
mbt
air max
clarks
nmd adidas
cheap ray ban sunglasses
coach outlet online
adidas yeezy boost 350
burberry outlet
cavaliers jerseys
air jordans
adidas sneakers
true religion outlet online
fred perry shirts
adidas trainers
polo ralph lauren pas cher
cheap jordan shoes
pandora jewelry store
red bottom heels
eahawks jerseys
ed hardy outlet
coach outlet online
louboutin shoes
nike uk
clarks shoes for women
parada bags
longchamp sale
yeezy shoes
bulls jerseys
moncler coats
nike outlet store
vans outlet
vans store
timberland boots outle
ray ban glasses
christian louboutin pas cher
cheap jordan shoes
rolex watches
jordan retro
yeezy boost
oakley sunglasses wholesale
nike tn pas cher
jordan femmes pas cher
rockets jerseys
cheap rolex replica watches
adidas nmd runner
montblanc pens
coach outlet online
gucci bags
birkenstock uk
adidas yeezy boost
thunder jerseys
jordan uk
louboutin outlet
birkenstocks
sac longchamp
ghd straighteners sale
adidas yeezy boost
coach outlet online
fitflop
adidas yeezy boost
birkenstock
celine outlet online
air max 90
fitflop
birkenstock outlet
ed hardy clothing
nike sneakers
fit flops
louboutin shoes
ray ban sunglasses cheap
ed hardy uk
adidas trainers
ralph lauren
chaussure louboutin pas cher
ghd hair
nike air huarache
ray bans
yeezy boost 350 v2
ray ban glasses
coach outlet online
coach factory outlet store
adidas superstar trainers
michael kors
polo ralph lauren
adidas superstar shoes
mlb jerseys whgolesale
pandora charms sale
tods shoes
birkenstocks
celine handbags
yeezy shoes
red bottom
kate spade outlet
kate spade bags
mbt
fitflops sandals
mlb jerseys
coach outlet online
cheap air max
longchamp bags
dansko
adidas sneakers
michael kors uk
adidas yeezy boost
cubs jerseys
ralph lauren uk
coach outlet online
fit flops
louboutin outlet
kate spade purses
pandora charms sale
dewfegf
