Actually there are two questions. You are having a shower at home and are nicely lathered up and the power fails and no more water from the shower. You still have running water in the bathroom basin and a choice of hot and cold water. What would you do?
The power goes off and your heating depends on having electric i.e. heat pump. Would you close all the doors of the rooms in your house to conserve any heat bearing in mind you are using the lounge area and will be in it for the next couple of hours depending on the length of the power cut or should you leave all the doors open?
First scenario happened to our neighbours and she needed to use water from the bathroom basin. Guess there is no other way to wash off the soap lather. Second scenario has happened to us a few times and always been unsure of what to do to conserve the heat as long as possible without having to use the gas heater.
