whats best mover for twin axel
Jun 15, 2009
17
I just bought new twin axel caravan and now thinking about a motor mover, but not sure to get two or four rollers.its not for getting on driveway just for sites? and not to close to ground Thanks.
Jun 17, 2008
113
Morning Darren,
I have just recently upgraded my caravan to a twin axle, therefore upgrade my Powertouch mover from a single axle to an All wheel mover (4 rollers). I have to move it on my drive. I was advised when speaking to Powertouch and looking at their website that if i upgrade to a 2 wheel mover it might struggle under the weight of the van.
It depends on your budget, 2 Rollers is
Dec 24, 2008
101
Hi Darren
I had the 4 roller one fitted to my Lunar Delta t/a it is worth its weight in gold ,why the hell i struggled over the years moving vans by hand .. i will never know .
Tom .
Dec 24, 2008
101
Hi Darren
I had the powertouch fitted it sits roughly half way up the road wheel and works extremley well.
Hope this helps.
Tom .
Oct 28, 2005
66
Darren
I have a two roller Truma on my S6 Wyoming which works fine and is a bit quite a bit cheaper if your budget is tight. It doesn't hit your MTPLM user payload as hard as the 4 roller kit either.
You MUST have a mover of some sort to get into the right attitude on some sites, but don't expect a twin axle to spin on its axis like a single because the centre of rotation lies betwixt the axles and no matter what claims are made for 4 v 2 there is still tyre scrub and the van swings slower. you just have to go back and forth a bit, not difficult.
Best bit of all is dabbing the controls to get a precise hitch up position - no more shouting at your beloved or smacking your prize motor!
Happy hunting.
May 21, 2008
2,463
I wouldn't bother mate. Just use the tow car if your only concern is parking the caravan on site?!
I haven't yet found a site where I could not reverse our 20ft twin axle van or or current 18ft single axle van onto the pitch with our 2 litre 2 wheel drive Laguna estate.
Much more impressive if you can demonstrate excellent driving skills.
Furthermore a lot of sites have their pitches set up so that you can drive on forward and off forward these days to make it easier.
Steve L.
May 25, 2008
771
" Much more impressive if you can demonstrate excellent driving skills"
Get a mover and make life easy,you can demonstrate to the watchers how good you are with a hand held remote control. Now that is impressive.
ps and you can also train the the wife in it use !!!!
we have a truma te and it moves our van ok, not with easy but OK, slips a little on wet grass and gravel
May 25, 2008
771
It's your towcar to ruin the clutch on if you so wish. Get a mover it saves all the hassle of cutting up the grass on narrow pitches etc. And it's unlikely you will bump your van on unforeseen hazards !!!!!
May 2, 2009
48
I have a Lunar Delta TL 26ft Twin Axle.... it has to be a powertouch all wheel mover model 6.... you should be able to have it fitted at your front door by them for
Oct 28, 2005
66
I'm with Gumbo.
Contrary to what Steve L says I'm just back from several weeks in France/Italy and plenty of pitches there it would have been absolutely impossible to get on facing the way you'd like in a towed direction. Maybe ok on UK club sites MOST of the time, but not always. And unless you're Tarzan or have many helpers next to impossible to get a twin ax positioned off towcar. And then levelling up without it - you must be kidding??!!!
It's less about what to get as most seem to work well within reason. Just get one!
4,769
We have the Powrtouch on the Wyoming but only two rollers. I couldn't see the point of four which would have meant resiting the spare wheel and some plumbing.
I don't use it for parking or storing but just on certain sites where we want the front facing the sea eg Scourie, Ardmair Point Berwick upon Tweed etc .
I've no regrets, and do believe it's an important piece of kit on a TA.
Dustydog
Oct 1, 2005
84
Hi all i am that Keith, my company is neleisureproducts if you want to search for it, We do go into lankashire, it depends where, we travel up to 100 miles of our location in Co Durham.
I try not to fit the 2 motor units as i dont like the disgusting looks from the customer when they find it wont really turn corners, the turning rate is 6 to 10 degrees at best, the Powrtouch AWD model 6, 4 motor unit will turn at approx 90 degrees & is a marvel to behold, i do it fitted for
Feb 19, 2006
158
Sorry I forgot to mention I had the 2 wheel drive on our previous caravan and it would not turn corners without burning the motors out every few months, the all wheel drive is great !!
Oct 1, 2005
84
Hi Simon, well you got one hell of a deal there, i can only think that they quoted you the wrong price & then had to honour the deal, as i couldn't even offer you the unit for diy fitting for that price, the rrp on Powrtouches website is
