Where does tv cable enter caravan, tabbert vivaldi 650?
Apr 21, 2009
6
i have 2 tv points within the van (factory fitted) but for the life of me cant find where to connect tv cable from the aerial. have looked everywhere including underneath?
Continental caravans usually have an external mains outlet for the awning and within this same box are the aerial input sockets and sometimes a 12vdc outlet.
Often, as with Hobby, the cable from these aerial sockets are loose under the wardrobe base and the coax from the caravan outlets are also loose in the same place.
If you want to connect an external aerial/dish to the internal outlets these cables need to be joined with an "F" connector.
If, however, you want to use a roof mounted dish/aerial above the wardrobe, then the dish/aerial can be connected to both cables, using a splitter, to allow TV to be viewed in the caravan and the awning i.e. the external inlet becomes an outlet socket.
I hope this makes sense to you but it is 03.30 and I should be sleeping!!
Apr 21, 2009
6
This guy must have been in a real hurry to get this information, why do we bother?
thanks for info rod.
no hurry?
have looked in those places and still not found, have setup my dish and im bringin cable thru side door temporarily.....
Apr 21, 2009
6
no hurry?
