Where is the fuse coming from the battery on a Bailey Caravan
Hi, I have totally lost all electric 12v in my van however if I plug the car in, it all works! I have been told that it will be a blown fuse, the one that comes directly from the battery but I cannot find it anywhere. I understand that they are difficult to find so has anyone else had this problem. Thanks in advance. Ally
Typically very close and less than 1m away from the battery, you may have to lift up cables for inspection if they are folded to the rear or side of the battery.
Hi and thanks. There are no fuses on the side or top of the battery but I am wondering if they are in the actual door casing as the cable goes through a closed in box through it if that makes sense!
Just follow the cables from the battery, and immediately behind the battery box and on the inside of the van you will find the fuse (in amongst a tangle of cables possibly).
