Which caravan wheel lock
JB1
Aug 4, 2022
85
29
4,585
Hi all I am I have an ALCO wheel lock the security shape is getting worn on both the receiver and the bolt and now it’s not easy to use plus I am getting board of jacking the caravan to get the wheel in the correct position to fit . I am look at replacing with either a Milenco Wraith 2 wheel lock, or the Purpleline Nemsis full.
i am trying to find out which is the easiest to use and look foreword to your replies . My caravan is quite old I don’t think it’s going to be targeted by hinend thieves may be chancers? I have a hitch lock and steady leg lock. There is no recommendation from my insurance . Thanks in advance .
Feb 13, 2024
1,353
856
1,435
I use Wraith 2 on my Lunar Venus 2016 no problem. If you change van take it with you as it fits most vans.
JB1
Aug 4, 2022
85
29
4,585
Hi thanks for your reply, does the wheel have to be in a specific orientation for the lock arm to sit on the floor or can it locate in various orientations hope this makes sense. Thanks
Feb 13, 2024
1,353
856
1,435
The wheel can be in any position, as the bar can be placed threw any of the Spokes. Check out you tube as there is a few videos of it in use.
Feb 13, 2024
1,353
856
1,435
Sorry mine is not no.2 model just bog standard one. You remove a wheel stud and replace it with the one that comes with it.
JB1
Aug 4, 2022
85
29
4,585
Thanks for reply it is the Wraith 2 I am looking at hence my concern re trying to find out if the wheel has to be a certin orientation
