Hi
I'm still dithering about which lighter gas cylinder type to change to. At the moment I use have 2 x 6Kg steel propane cylinders from a local distributor, so I don't have any Calor bottles to swap if I went for Calor Lite.
I'm aiming to swap before we go for our 31 day trip to Croatia and Slovenia in 2 weeks' time. I've been doing some research but still have some questions I thought the folk on the forum could probably help me with?!
To Calor Lite users:
(1) What are the actual tare (empty) weights of the Calor Lite Cylinders? (Calor just say how much lighter they are than the older type of steel ones)
(2) What the current costs for Calor Lite? - I'd probably need to pay the deposits and gas charges for 2 bottle as I probably won't have any old type Calor ones to exchange
(3) Am I right in understanding that the Lite cylinders are simliar dimensions to the older Calor steel ones?
(4) Could I swap old type Calor steel cylinders for Calor Lite ones, if I obtained some older type from a friend?
(5) Am I right in thinking that I could use my current pigtail connectors from my bulkhead regulator with Calor Lite?
(6) Are the gas-trac gauges on the Calor Lite cylinders any good?
To BP Gas Light Users:
(1) What are the current costs of the BP Light Cylinders, 5 and 10 Kg?
(2) Am I correct in understanding that I would need to buy a clip connector and new, butane type, pigtail for each BP cylinder?
(3) What are the 5 and 10kg BP cylinders like for fit and how well do they secure? My front locker has a moulded base plate, curved plastic plastic brackets and straps for 2 steel cylinder. I have measured my front locker but I'm still not sure as to how well one 10Kg or 2 5Kg cylinders would fit and be secure!
(4) Are alternative clips, straps and base available and/or necessary for BP Lite cylinders? Where can they be bought, if needed?
I'm attracted by the see-through aspect of the BP cylinders, the compatability of the fittings with some Continental cylinders and their lightness but I'm concerned about their fit in my front locker and their apparently more limited distribution network. In addition I like the idea of being able to use the 10-15% vouchers which I'm regularly sent by Homebase and I don't like Calor's near monopoly.
Sorry to ask so many questions but I know there are a lot of people on the forum with the experience and answers.
Thanks in anticipation
Tim
Tim
