Which tow car
Jul 19, 2021
615
426
5,135
I'll add that up to 1600kg my old 2015 VW Tiguan 4 motion was great, it was a Diesel manual but I would go for Auto if possible, but they are a DSG box on some of those so ?
2,271
Many cars will tow that sort of weight so you may be confused by so much choice. We have a similar weight van and tow it with a Mercedes GLA 220d. Max towing weight is 1500kg but noseweight capacity ( S rating) is only 75kg. Although that is not a problem to us.
It has good fuel economy when towing ( around 35-38 mpg).
We also have an electric Corsa so use the merc for towing and longer journeys and the Corsa for the majority of our day to day driving.
If the tow car is going to be your only car, then do consider day to day solo driving needs; you will be looking for a car that is good for both.
665
306
2,135
Thank you TM. This sounds like potentially good advice, but I’m a little lost in the technical info. It sounds as though something is being added here to modify the car’s function. Are you in the UK? Any modifications have to be declared on insurance here and could lead to a higher (or even refused, but that’s guessing) premium.
Scross is Vitara slightly bigger brother. If you look at Suzuki go for mild hybrid with 1.4turbo. The full hybrid uses gutless 1.5 non turbo engine. All hybrid range is rated to tow 1500kg.
If looking at older non hybrid range they are only rated tow 1200kg.
NB Top of range AWD Scross has 360 degree camera.
Toyota RAV4 hybrid is quite bit bigger and rated for 1500kg with similar fuel economy when not towing.
With any petrol( including hybrid )car when towing caravan you can double the fuel consumption.
Best advice is do some test drives.
9,153
My RAV 4 hybrid is only rated at 800kg braked load. The AWD hybrid is 1500kg braked load.
3,613
I've never found that in 40+ years of caravanning - my towing consumption has always been 50% higher than the same car solo - that's been true for small and large engined petrol cars as well as turbo-diesel ones.
May 30, 2024
107
118
635
That's not a bad worst-case assumption, whatever fuel type your car is.
Your outfit is likely to be about double the weight of your car alone, and double the wind resistance. In which case, the amount of energy or fuel it takes to move the whole thing (at the same speeds and accelerations) will also be double. Doesn't matter whether it's petrol, diesel or electricity.
Then some things will make the impact of towing on fuel consumption not quite so severe.
You probably drive slower, with slower acceleration.
You might have an unaerodynamic SUV, so adding the caravan on the back doesn't make the wind resistance so much worse.
Your towing vehicle might be much heavier than the caravan, so actually the weight of the outfit isn't doubled.
Whatever the specifics of your outfit, it's still quite a shock the first time you figure out how much more fuel you're using!
4,359
Throughout my life I have probably towed with more different combinations of trailer, caravans and tow vehicles with th eexception of perhaps caravan journalists. and whilst I haven't always kept tabs on fuel efficiency on the occasions I have, I cannot recall a single outfit that lost 50%, typically more like 30 to 35%. But realistically there are so many variables that might account for 5% or more on their own.
The one thing that doesn't translate is speed, when towing you are typically going tp be doing 6/7ths of your solo speed in th eUK at least. If you were normally driving solos at 6/7ths speed you would be surprised at how much better your fuel mileage would be, so that can make a big difference.
However for budgeting purposes if you assume towing will only get you half as far, then you'll get a nice bonus at the end of the journey.
Reactions: cencerrita
Jul 29, 2024
12
I'm reading your advice on Suzuki Vitara with great interest as by incident there's a decent Scross GLX for sale near me. Couple of questions
- What tow bar did you equip the Vitara with? There's no towbar option in the dealership price catalog.
- The manual gear/mild hybrid option is rated for 1500kg of braked towing capacity, but it also quotes 1265kg of vehicle weight, with a 'full weight' figure of 1710kg, most probably meaning 4 adult passengers. My caravan's 1300kg w/o our gear.
Jan 20, 2023
1,309
1,165
2,435
The Fiat 500 (IC engine models) have a towing capacity of 800 (or 850?) kgs so with such a light caravan there are many options, but as others have said, some cars that you'd expect to have decent towing limits might not have any at all. Also limits can vary wildly for the same model depending on engine, transmission etc, etc......
A Fiat 500 Abarth would have plenty of grunt m=but I don't think they're type approved for towing!
Aug 12, 2023
665
306
2,135
If it was me I wouldn't buy Scross or Vitara to tow a caravan over 1200kg(MPLM) even if rated for 1500kg. These vehicles are too light and short(wheel base) to comfortably tow caravans over 1200kg regularly.
For 1300kg van you really want to look at medium SUVs eg RAV4, Sportage, CRV, CX5 etc. Other plus of larger vehicles is bigger boot for all extras (awning, barbecue, camping chairs) that is to heavy for caravan to carry.
9,153
I wouldn’t rule out an estate car, we’ve had some excellent estates as tow cars.
Aug 12, 2023
665
306
2,135
If it was me I wouldn't buy Scross or Vitara to tow a caravan over 1000kg(MPLM) even if rated for 1500kg. These vehicles are too light and short(wheel base) to comfortably tow caravans over 1000kg regularly.
In my case I bought Vitara new to tow light boat, caravan was maybe at time. 1200kg limit on our model limited our options when changing to 4 berth. Don't feel unsafe towing 1150kg caravan but if changing vehicles would definitely upgrade to medium SUV.
For 1300kg van you really want to look at medium SUVs eg RAV4, Sportage, CRV, CX5 etc. or bigger. Other plus of larger vehicles is bigger boot for all extras (awning, barbecue, camping chairs) that is to heavy for caravan to carry. If caravan upgrade is on wish list I'd go for vehicle with higher tow rating eg 1800kg( CX5) then you have more choices without having to replace tow vehicle day one.
9,153
With 2019 onwards RAV4 you need the 4WD variant as the 2WD hybrid only tows 800 kg braked trailer whereas the 4WD hybrid does 1500 kg.
4,359
I've modified my post a bit. SUVs dominate NZ market hence example. I'm big estate fan but they are dying breed in NZ.
One of the things that has always fascinated me is how you can go to another country and see cars with familiar names, that look entirely different, and in fact are actually very different. And on top of that the technical specifications for things like towed weight limits, and nose load limits can be very different to the UK's models, because of the way the local construction and use regulations have to be applied.
For that reason, there is no certainty that a RAV 4's specifications will be the same in UK and NZ, and what values are given, might refer to differently defined criteria.
5,296
I had one as a loan car and hared driving it. Horrible little car!
  • Haha
Reactions: GaryB
5,296
The Suzuki Across and RAV4 are virtually identical as they use the same power train.
Reactions: xtrailman
Jul 29, 2024
12
Coming from a 2008 Sorento, I sort of agree with you. Most of my towing experience was with this big and heavier than average car so I wasn't sure what to expect from these lighter options. I'll follow your advice.
3,613
In particular, Australia uses lots of models which have much in common with EU/UK cars but also have some notable differences due to Australian Design Rules (ADR) - specifically in noseweight limits and engine emissions which are a couple of generations behind EU/UK emissions regulations - I'd love to be able to buy an Australian spec Touareg, with a 280kg noseweight limit, a V8 turbo-diesel and only half the troublesome emissions equipment.
I believe that New Zealand uses regulations very similar to Australia.
Reactions: GaryB and ProfJohnL
Mar 10, 2006
3,274
47
I wasn’t impressed at all with my Tiguan 190ps diesel Awd towing 1650kg, I’ve driven a 190ps GLB since and that car had much more pulling power.
