Hello Tony,
If you contact Bailey direct they will tell you that Only Care-avan is acceptable to use on a Bailey Caravan.If you visit our web site you will see the Bailey Statement.
Many Thanks,
Derrick
WHAT A LOAD OF RUBBISH,HERE IS THE RESPONSE FROM FENWICKS
FENWICKS IS OK WOTH BAILEYS
With reference to the information sent out to Bailey Caravan Dealers. Fenwick's pride themselves on the quality and performance of their products. Their technical knowledge and expertise is highly regarded by customers (the trade, end users and manufactures), The Caravan Club and the Camping & Caravanning Club due to dedication and devotion to the caravan industry for over 13 years. With regard to the Bailey Owners Manual Fenwick's Caravan Cleaner is not dissimilar to car shampoo and does not contain any of the chemicals referred to in 5.1.1 (abrasive agents, methylated spirit, white spirit, other solvents or washing up liquid). Therefore to "wash the caravan regularly with a car shampoo" would give similar results as washing with Fenwick's Caravan Cleaner. So why would this invalidate the warranty offered by Bailey Caravans Ltd.
There has to be an existing defect in the material or the way the it has been used for the cracking to become visible to the naked eye after washing. This is not ruled out by the test results as the information provided states that "when Fenwick's Caravan Cleaner was applied to the ABS surface severe cracking became noticeable" Not that it caused the faults in the first place. We understand a material supplier to Baileys is Thompson Plastics.
In their product information sheets Thompson Plastics state that their material can be cleaned with Carafax Concept Parts Cleaner, Humbrol Low Aromatic White Spirit Cleaner and Carafax Distillate Cleaner. Thompson Plastics also state that "the panel should be free of fitting stress", "distortion will increase stress in the moulding and could result in visible surface fractures over time." and "Resistance to any given chemical substance is conditional on the products being installed in a stress free condition." Extremely important considerations as stress could cause visible surface fractures to appear.
Thompson Plastics commissioned independent testing which proved that "the material (Fenwick's Caravan Cleaner) is not deleterious to capped ABS in the relaxed condition."
So if there was any misunderstanding that Fenwick's Caravan Cleaner could void the warranty of a correctly manufactured and fitted part, then they are sadly mistaken.
Regards,
Jonathon Smith B.Eng Director
