Why are touring caravan boilers not “on demand”
Feb 13, 2022
553
407
1,135
It took me a while to understand how the Truma Ultrastore system in my caravan works. I always assumed that a touring caravan boiler would be similar (if smaller than) to the combi in my flat or the on demand boilers you get in all static caravans. What is the technical / practical reason than touring caravan water heaters have small tanks rather than heat on demand? I understand the electrical limitations but I’d be happy to run hot water off gas if it meant unlimited hot water and the technology allowed.
3,811
On-demand hot water needs high power than stored hot water, running the risk of tripping site electrics especially those where the full 16A isn't available.
Reactions: Seasider
2,770
My combi instantaneous home heating is 32 kw. The Alde in the caravan is 3 kw max on electric, and 7 kw if gas is used as well. And don’t forget, that leaves
nothing remaining to make a cup of tea.
Another reason is home combi’s work at mains pressure, caravan systems are not built for that.
Then there is the economics.
1,819
We have the Truma, and while continuous running water would be nice we have never had any problem with the quantity in the tank. Possibly the problem is that if you have the water running for a shower and run out of water in a container which most of us use it could burn out the pump and damage the heater, although the Alde users might tell me otherwise.
Reactions: JezzerB
Mar 8, 2009
1,851
334
We cheat! We feed the Truma water heater with 'hottish' water from a spare water bottle, which we warm up with hot water from the kettle before we start showering. So the 'boiler' is fed hottish water to virtually 'double' its capacity & speed of hot water supply. When needs must! In fact thought about putting a 'small' immersion heater into the bottle. But haven't got round to it, probably shan't now, as 'retiring'!
Reactions: Kevin M and Hutch
4,449
... What is the technical / practical reason than touring caravan water heaters have small tanks rather than heat on demand? I understand the electrical limitations but I’d be happy to run hot water off gas if it meant unlimited hot water and the technology allowed.
As RogerL has stated its question of what power is available, and without doubt the limited 16A mains supply would not be enough heat the water demanded on a continuous basis.
There are also historic technical reasons why gas systems were not available to produce instant hot water in caravans. In the distant past there were instantaneous water heaters in some caravans. These were technically like the old fashioned Geyser water heaters with used direct water heating with an open flame. These were outlawed for safety and efficiency reasons. Having an open flame and the way they burned meant they produced unsafe levels of carbon monoxide and dioxide which were able to be vented directly into the caravans living space. They also used a lot of gas which meant the volume of the flue gasses would easily begin to overwhelm the caravans limited ventilation. Such types of heater were made illegal as all dedicated gas room or water heating has to be room sealed which prevents any flue gassed entering the living space of the caravan.
The second reason was legislation that directed all gas appliances must prescribed levels of energy efficiency, and geyser type heaters were not able to guarantee they could maintain the required thermal efficiencies.
I know from personal experience how difficult it is to design and engineer high capacity gas burning systems that can operate in a small space, and the caravan manufacturers of the day were not prepared to entertain a heater that took up more physical space, so the development of instantaneous water heaters for touring caravans was not economical.
What changed the game was the introduction of Alde heating whose vertical form factor can bee better accommodate the necessary heat exchanger size and shape to enable higher gas capacity burners to be used.
Feb 13, 2022
553
407
1,135
Thanks for this detailed answer, it's very informative.
