i have been following this one with interest, as i also cannot fathom out the simple workings of my heating system.
first and foremost, remember i am the newbie in here and what might seem puzzling to me will be obvious to you folks.
my caravan is an abbey aventura 2001 model with the truma space heater and blown air system, there are two switch panels at the bottom panel of the right hand front seat, one is marked space heater and is the same as an ordinary domestic on/off switch, the other is a panel that has various settings, 500w, 1000w and 2000w, plus a thermostat type ring for setting temp.
i cant get my head around how to work this set up properly, if i want to use the heater without the blown air what settings di i use ? is it just a matter of switching on the bottom panel with the space heater switch ? and do i have to have the switch on the heater set to the left for manual, set to the right for auto, or will the heater operate with the switch in the middle position ?. every time i try it, there is no heat whatever coming from the heater, the only way i can get heat is if i use both panels and have the fan blowing the air out of the vents, can i not shut the vents, or switch them off so that the heat comes from the heater ?,
sorry if i sound like an eejit, but the handbooks dont give much info.
hope you understand what im trying to ask, kinda hard to explain with type, i know it will be simple, but until someone tells me, i will freeze.
cheers.
btw, when i switch everything off, i can feel some heat from the space heater, wierd .
