Wireless reversing camera
Mar 26, 2018
Wireless camera on 2017 Swift Sterling 645 standard figment.
16 months still not operating keeps dropping signal, 4 dealer visits over 7 weeks, all items replace many times by dealer.
Swift cant fix now saying it’s my tow car fault, a VW Transporter T30 Kombi swb with rear and side windows, same size a Range Rover , discovery etc need a large vehicle to tow this size.
Any one had similar issues advise welcome
936
Wireless cameras are notorious for dropping signals unless the conditions are absolutely perfect.
Your vehicle is basically a large metal box which is perfect for blocking signals.
Nov 6, 2006
731
5
18,885
I bought my system from https://www.parkingcameras.com/store/home.php who are very helpful, and have different cable lengths available. The camera will be connected by cable to a transmitter unit somewhere in the van, so you might consider moving this much nearer the front of the van with an extention cable. Equally, you might ensure the receiver in the car is as far rearwards as possible too.
Mar 10, 2006
3,274
47
Swift fit the transmitter just above the number plate usually.
My system supplied by parking cameras has never dropped the signal, they only sell the latest digital types.
But to help things along and for convenience I fitted mine in the front of the caravan. Range is around 100m for a clear path. RX in car is upfront under the glove box.
Mar 10, 2006
3,274
47
Not cheap.
https://www.parkingcameras.com/store/12v-small-indoor-only-digital-wireless-link-bridge.html
Nov 6, 2006
731
5
18,885
Typical Swift - make it a selling point but execute as cheaply as possible..
I fitted my transmitter in the wardrobe in the centre of the van as this gave me good access to the 12v feed to the fridge, so the system is ignition controlled. The received is as far back in the car as I could fit it
Mar 10, 2006
3,274
47
I supplied my rear view camera from the permanent feed, using the reversing signal to switch over a relay to select the reversing camera.
