Hello. if your set up is like mine the fridge only operates on twelve volts when the car is connected and the engine is running. That is the only time the red twelve volt light operates.
Hopefully someone with a modern van like yours may comment.
I believe that the car only sends 12 volts when it's own Alternator/Generator is above a certain voltage. By that I mean with the engine running fast enough to produce the correct voltage.
I am guessing that when you are doing your check your car engine is just ticking over which could explain why your fridge light is flashing.
It could be worth just trying again and getting someone to just increase the car revolutions slightly by putting their foot on the throttle. This could increase the voltage supplied and cause the fridge light to become steady.
It could also be that your fridge is designed to show a flashing red light when operating from the cars twelve volt system. But my older fridge the red light doesn't flash when operating.
I do feel that from what you have said that your fridge is working ok.
Remember once you get to site you will connect to mains power anyway or alternatively use the gas function on the fridge if you are on a site with no hookup.
Most people if they store their caravans at home connect their vans to the mains and operate their fridge for a day or so prior to setting off to get it nice and chilled then the twelve volt operation from the car is purely to just keep the fridge chilled during the journey.
I hope you soon get sorted and have a lovely holiday
Best wishes Brian
