I have recently purchased a (used - 1998) Crown Sovereign and was checking how everything works last night (I am new to caravanning).
Whilst checking the water heater, the water flow was intermittent from both hot and cold taps. I assumed some kind of airlock in the system, so I drained the water heater (the heater had water in it already), so I could then re-fill it. Before I drained it I noticed the water coming from the cold tap was warm too.
When I put the submersible pump into the water container, and turned on the taps, the pump ran, but it only took a small amount of water in (even though the pump kept running) The pump was fully submerged. Does it matter if the pump rests on the bottom of the water container?
I noticed that there was a noise (a king of chugging, or knocking) coming from the water heater when the tap was first turned on and the pump ran, it then stopped after a second or so, the pump then continued to run.
Does turning on the cold tap also fill the heater?
I rang the dealers service department and they seem to think that the heater's non-return valve needs replacing. They said this as the hot water coming from the cold tap and the fact that the chugging is happening and the pump seems to not be drawing any water in.
Is there a chance the pump is damaged as it is running but no water seems to be coming in the heater? Roughly how long will it take to pump in 6 or 9 liters (not sure which) into the heater tank, 5 minutes . 15 ???
They will do the work for me as I have only had the 'Van for a couple of weeks. I am so glad I checked this before we went away !!
My apologies for the essay, but I would appreciate any help as this is all new to me. Thanks again.
