- Jun 6, 2012
- 175
- 0
- 0
Hi all, I am just asking whether you should use a pressure washer to clean your van to get the streaks and road film off, or will it damage the decales and bodywork or shall i stick to doing it by hand?
AbbeyOwner said:Hi all, I am just asking whether you should use a pressure washer to clean your van to get the streaks and road film off, or will it damage the decales and bodywork or shall i stick to doing it by hand?
I've applied wax earlier on and polish, but do you think i could use the foam gun attachment to foam the van and then clean by hand?Parksy said:Hi Abbey Owner
I wouldn't really recommend the use of a pressure washer for cleaning a caravan and a pressure washer won't remove black streaks from caravan paintwork.
As you mentioned, the caravan graphics could easily be damaged by a pressure washer and mastic joints could be damaged which would lead to water ingress.
If you have a lot of black streaks which keep coming back you need to clean the roof of the caravan. When the caravan is not in use set the jockey wheel so that the caravan is nose down which will prevent water and grime from collecting on the roof.
Use a normal hose pipe to wash and rinse the caravan with caravan shampoo, then use a good car polish which will remove any remaining black streaks and road grime.
You only need to polish once a year if you add a coat of wax ( not polish- there's a difference between the two) and buff it up. With a good wax coat, applied at the start of the season, the streaks and grime will wash off much more easily.
Hi Sir Roger, Thank you for the advice yesterday i rubbed the black streak with one of my cleaning cloths and it came straight off, But still going to give it a clean this weekend so i will pop into poundland and grab a bottle and also a new bottle of super resin polish and dig my clay bar out of the garageSirRogerFFS said:Hi AbbeyOwner . I have replied you quest in The General Topic. CERTAINLY NOT to the pressure washer.Now to join together some of these comments on here I have used Mr Sheene but when you have removed the Black Streaks wash and wax with a good wax polish. Also if you go to your dealer you can buy a beading that goes all the way your awning channel and stop water running down from the roof or as Parksy has said when you park up park sligtly nose down and let the water run down the front. Good Luck .
Sir Roger.
not that simpleSurfer said:Many dealers wash your caravan with a pressure washer and if you do it right no issue, but if you lack common sense don't try it. Simple answer.![]()
Super resin polish - YesAbbeyOwner said:............... But still going to give it a clean this weekend so i will pop into poundland and grab a bottle and also a new bottle of super resin polish and dig my clay bar out of the garage![]()
There are a bewidering array of products on the market now DD and because Abbey Owner mentioned super resin polish earlier in the thread he might prefer wax sealant, which is made by Autoglym as it happens.Dustydog said:You're slipping Parksy!!
You didn't mention Maguires or Autoglym, never mind that elbow grease stuff you use![]()
At the end of the day it's your foam gun and your caravan, you've seen the advice from other caravanners, some for and some against using a jet washer.AbbeyOwner said:Thank you all for the advice, would it ok to
use to get rid of the road film from underneath and use the foam gun on
the van from a distance so that it doesnt damage the window seals and
decals, But it currently has a coat of super resin polish so shouldn't
take a lot of effort to remove the black streaks.
Thats the last thing I want before i go away a water ingressed caravan, I cannot take a risk with using high pressure to clean it, but is there a cheaper price for fenwicks as Halfords are charging £11.99 for it, It also takes a lot of effort to set up and put away so probably will stick to using elbow grease to clean it and then leather using bobby dazzler (hopefully no rain will cause black streaks )Parksy said:There are a bewidering array of products on the market now DD and because Abbey Owner mentioned super resin polish earlier in the thread he might prefer wax sealant, which is made by Autoglym as it happens.Dustydog said:You're slipping Parksy!!
The reason that I prefer Meguiars step 3 (there- I've mentioned it now!) is because the carnauba wax gives a deeper longer lasting shine than the wax sealant which is synthetic but it's a matter of personal preference![]()
Make a decision based on which advice you think suits your own circumstances the best.
I own a Karcher jet washer with a foam gun etc which I use on the car on the rare occasions that I give it a thorough clean. The jet washer is great for removing salty deposits, mud and grease from underneath the car.
I don't use mine on the caravan but the caravan is stored inside a farm building so all I have to worry about apart from mud from caravan sites is a bit of dust.
I have to connect the jet washer to my hose pipe but why would I bother? I
It's much easier for me to just use the spray attachment on the hose to rinse the caravan without having to get the Karcher from the garage and plug it in. Even if I used the Karcher I'd still have to use the wash mitt by hand to rub in the Fenwicks shampoo that I spray on first, so it makes no sense for me to use the jetwash even if I wanted to ( which I don't because of the decals etc)
Decide what works for you, what is the best way to acheive the result that you want and the easest way to do it without risking damage to your caravan in any way.![]()
