Xplore 304 grey water push connector size
Rod
Sep 4, 2020
Anyone know the size of the hole for the grey water waste?
28mm rubber push fit???
Thanks.
9,564
Thanks.
That’s a pretty standard size if you are buying the convoluted flexible hose. 28.5 ID and 32mm OD
Reactions: Rod
Jan 19, 2002
1,711
551
As Clive has replied the waste on current caravans is a standard size 28.5mm inside diameter to fit the standard waste outlets that usually sit somewhere behind the off-side wheel.
Rod
Sep 4, 2020
Thank you.
Regards Rod
