please help 12v fridge has stopped working while i travel any idea what it can be ? and is it car or caravan want to chect most things before i pay for help
i have a bailey pageant 1997 cheers
andrew sparrow
Jul 25, 2005
164
Hi Andrew, Have you tried to search the forum for past answers to your problem?
Try searching for fridge and you will get about 24 answers related to fridges and one at least may assist you with your problem?
Hears hoping and best wishes,
Pop
Andrew, Check for 12v (+) on pin 6 and (-) on pin 7 of the car 12S socket when the car engine is running. {older vans (+) on pin 6 (-) on pin 3.
If the voltage is present connect it to the car with engine switched off . On post 98 vans switch on the caravan internal lights. Start the engine and the lights should go out - this proves the fridge supply is getting to the van ( the fridge supply switches a 'habitation' relay in the van which disconnects the supply on pin 4 (+) from powering the van 12v to charging the van battery.
If the lights go out check for 12v at the fridge. If it is getting there and the fridge is switched on then suspect the 12v element.
Andrew, I see your van is 1997 so it is possible it is either the earlier or later system.
