- Mar 9, 2006
- 39
- 0
- 18,530
Hi all,
I was hoping that you might be able to help me with my troublesome Vetcra?
1, I have just found out that I should have a dashboard repeater for the indicators whilst I am towing with my Vectra, it should be a little towbar symbol in the bottom right corner of the dashboard (according to the owners manual), Only mine does not illuminate!?!?!, the car has got its own bulb failure warning system, does this override the need for the repeater?
2) Whilst towing, but not all of the time, the car often goes into Safe mode, as Vauxhall call it (total loss of power) and has always been diagnosed as problems with the vacuum system for the turbo, anyone else any experience of this phenomenon?
4) I also have a fault with the N/S front indicator which intermittently illuminates on its own but does not flash, the bulb failure light comes on the dash. The fault does not accur if the side/main lights are on. The car has been back to the main dealer countless times but cannot fix the fault. I have disconnected all the towbar electrics in the hope that would cure it but sadly no. Has anyone else heard of the problem?
Get rid of the car I hear you all say, hence my next question.
5) Is the new shape Vectra 1.9CDTI (150Ps) going to be any better than what we already have, I have lost a lot of faith in Vauxhall?
Thanks for reading, any help is most appreciated.
Gazza
Gazza
