Gas pipe fittings. In the gas locker there is a three way tee piece which taps off from the regulator outlet for the external BBQ feed. I am in the process of re-siting the regulator higher up to avoid contamination from any residue in the gas, as I don't want to compromise my nice new regulator.
The new regulator has its own dedicated olive but I need to source a new olive for the end of the new, longer pipe where it fits into the tee piece. I cannot locate one of similar appearance and I'm hoping that a fellow contributor or even someone from Swift could maybe advise where I could obtain a correct olive to reconnect to the tee.
I've separated the fitting from the two pipes to show the olive hoping it can be identified.
TIA
Pete
TIA
Pete
