2011 bailey caravan drawers
Sep 18, 2007
57
how do i remove the drawers to get the space heater thats not working on elec 2011 bailey Pegasus
Oct 8, 2006
2,070
732
If the OP is talking about the front drawer set, just pull the drawer fully out and give it a sharp upwards pull at the outer end - the drawer will lift off the runners. Putting it back can be a bit fiddley because as soon as the drawer is placed on the extended runner, the runner moves. If that happens just push the drawer closed - it will not go all the way - and apply pressure to get it to go fully home (it clicks.)
Sep 18, 2007
57
thanks Jcloughie for the heads up on YouTube unfortunately i could not find anything to help but will keep YouTube for any other prob that come up so thanks again
Woodentop the drawers are under the worktop in the kitchen area above the gas/elec fire i have pushed pulled lifted and can find no secret buttons or any thing else that will give so i will have to wait for service time
2,298
There weren’t any that I could find on my drawers either. I think some folks remove the little screws on the runners.
4,672
I think our drawers have little screws on the inside to release the drawers.
2,627
You will need some long nose pliers from underneath to ping the 2 barbs of plastic clips out of there slots each side then from above with one hand on each side of the plastic drawer squeeze both tabs outward, wriggle the drawer whilst pulling upwards .
Don"t forget to clip the 4 barbs of the tabs back into place after you re-fit the drawer ( Our caravan engineer this is what he did with our bailey caravan we had some years ago it might have the same fitting )
Reactions: captain1
Sep 18, 2007
57
Beachball thanks i had seen the plastic clips but could not see what they did so with your help drawers are out or should i say off so thanks again Beachball and all who tried with suggestions and i will remember You Tube could be handy for lots of other projects if not this one
Reactions: Hutch and Jcloughie
