Ads910 said:Been trying to find a car that is mam 2100kg and capable of towing a 1400 max weighted caravan, my 2.0 petrol qashqai just don't have enough power
Presumably it does not need to be 2100 precisely (or he could add a 10 gm weight!).Raywood said:Finding one at exactly 2,100 is difficult but the Mazda 6 with the 175 PS engine and manual transmission is 2,090
That's true, if that is the reason why he wants his car to be close to 2100 kg. Depends when he took the driving test.weight of the jeep plus caravan MTPLM would exceed the OP s 3500 kg licence limit
Raywood said:... but it is the gross vehicle weight plus the weight of the trailer that counts in law.
DrZhivago said:Presumably it does not need to be 2100 precisely (or he could add a 10 gm weight!).....
ProfJohnL said:Raywood said:... but it is the gross vehicle weight plus the weight of the trailer that counts in law.
Sorry Ray not quite righ!t.
The law requires the combined MAM not to exceed 3500kg, What youhave actually stated si the GVW ( MAM) of the car but only the weight (i.e. a measured value) rather than its weight limit.
Its s subtle but very important difference which even the Govt web site got wrong and we had to point it out to them, and it has since been corrected.
Jaydug said:Ads910 said:Been trying to find a car that is mam 2100kg and capable of towing a 1400 max weighted caravan, my 2.0 petrol qashqai just don't have enough power
That shouldn't be too difficult. Two guys I know both tow caravans of around 1400Kgs. One tows with a 2013 Mondeo with 163bhp diesel engine and the other uses a Peugeot 508SW also with a 2ltr diesel. Myself I use a Citroen C5-X7 with a 2ltr diesel engine.
Raywood said:Prof, I am not sure I follow you here. You state in the next post that the MAM and GVW are the same thing. Surely the GVW is its weight limit as if you exceed that you are beyond the cars theoretical safe limit.
It does occur to me that the towball load should be within the GVW although what difference it would make I am not sure but part of the MTPLM is being carried by the car so your example might just be legal.
Raywood said:.... now I see your position on actual weights.
On reflection I am not sure I would go so close to the limit as if you then change the caravan then you are limiting your replacement choice to exactly the weight you have and may have to rule out what you want for the sake of a few kg.
Raywood said:Prof, I think we agree but missed each others point. What I meant here was that with a 1400 kg trailer the OP was within 3,500 kg although the cars towing limit was 1600 kg which is over it. Possibly I was not clear in that it is the MTPLM of the trailer provided it is not overloaded that is relevant here, which is just within the limit as looking at it now I see your position on actual weights.
Buckman said:It does not matter one iota what the trailer actually physically weighs and even it if was empty and the sum of the gross maximum weight of the vehicle plus the MTPLM of the caravan is taken and it exceeds the 3500kg then points on your licence and a fine. Many people think that because a trailer is empty the DVLA or police will only look at the weight of the trailer however they will look at the MTPLM of the trailer and use that figure so beware.
The B+E test is exactly the same test as HGV drivers do to add artic entitlement (C+E) just in a different vehicle and trailer! When I did C+E some chaps were doing B+E. The main thing people often worry about is the reversing exercise. Can I reassure you that almost all driving schools use a twin axle trailer for this, and twin axle trailers are infinitely easier to reverse than single axle trailers. You have time to think and correct things, the extra drag slows things down. (In fact even though I can drive an artic the thing I hate reversing most is a small single axle car trailer as by the time you see it in either mirror it is far too late to do anything to correct it!)Ads910 said:Thanks for all the replys.
Maybe I'll do some practicing in my current car then go for the rest.
Thanks everyone
timhowarduk said:..... twin axle trailers are infinitely easier to reverse than single axle trailers. You have time to think and correct things, the extra drag slows things down. (In fact even though I can drive an artic the thing I hate reversing most is a small single axle car trailer as by the time you see it in either mirror it is far too late to do anything to correct it!)...
