CRIS Registration problem
Apr 20, 2023
7
We have a 1986 Avondale Mayfly and I am trying to get it CRIS Registered but they keep asking me for the Serial Number. I'm not sure where to find it ? They say that it should be stamped somewhere on the ALKO chassis frame but unless I can get on the ground under the caravan to look I've no idea whereabouts it is.
Any ideas ?
Many Thanks
Les
Sep 23, 2023
955
352
1,135
That's the first time this method was used as Dusty pointed out.there are instances of certain manufacturers have a "VIN" number stamped somewhere/Anywhere on the chassis,no hard and fast rule pre 92
Sep 4, 2011
313
119
18,735
Likely stamped on A frames and underneath the cover. Our Caravans we had in the 70’s and 80’s was on the topside of the frame on the left side looking from front of caravan.
1,669
514
Is there a serial number listed on the plate by the entry door that gives the weights for the van? On my previous van there was also a plate in the centre front of the axle cross member.
You should be able to insure it without the registration from the model and year of manufacture which may be relevant to your concern.
Apr 20, 2023
7
Yes, it is to do with getting it Insured. Having found a Company that will cover older 'vans the first thing they asked was does it have a VIN or something to identify it... But thanks for coming back to me.
4,728
Les .
13 years ago someone wrote this on another forum. Same make model and year as yours. Note the VIN number and its location.
This one looks like it was made in 1985 but got registered as a 1986 one. Not uncommon.
I'm hoping someone can help me with a question about my newly purchased Avondale Mayfly. The sellers were unsure of the age or weight of the caravan so all I have to go on is the VIN which is shown on a metal plate inside above the door and etched on every window. It reads 1 85/0362.
2,379
On your Avondale Mayfly have you a metal label above the door that says 1860945 someone told me that the 2nd and third digits of the serial no was the year it was manufactured in your case it 1986 , So I hope this might be what you need and good luck.
7
Oh my goodness ! yes it does... and it says: 1 86 0945
I feel such a fool, it was there all the time - right in front of me, and here's the proof (see image).
Thank you to everyone who joined in to this - you are all given a Gold Star
Now all I need is to find some replacements for the rather sad front decals(see 2nd image)
Les
