CRIS Registration problem
Apr 20, 2023
We have a 1986 Avondale Mayfly and I am trying to get it CRIS Registered but they keep asking me for the Serial Number. I'm not sure where to find it ? They say that it should be stamped somewhere on the ALKO chassis frame but unless I can get on the ground under the caravan to look I've no idea whereabouts it is.
Any ideas ?
Many Thanks
Les
Sep 23, 2023
941
341
1,135
That's the first time this method was used as Dusty pointed out.there are instances of certain manufacturers have a "VIN" number stamped somewhere/Anywhere on the chassis,no hard and fast rule pre 92
Sep 4, 2011
307
113
18,735
Likely stamped on A frames and underneath the cover. Our Caravans we had in the 70’s and 80’s was on the topside of the frame on the left side looking from front of caravan.
Jan 19, 2002
1,666
512
Is there a serial number listed on the plate by the entry door that gives the weights for the van? On my previous van there was also a plate in the centre front of the axle cross member.
You should be able to insure it without the registration from the model and year of manufacture which may be relevant to your concern.
