2nd hand towbar and car. Help please
Oct 24, 2024
116
64
635
We have purchased a Volvo XC60 with a towbar already installed.
I have plenty of experience towing and being quite fastidious about nose weight - but that was about 15 years ago and I haven't towed since. And 15 years ago my memory was a bit shaper than it is now.
This is my first post, and I'm already asking for help; forgive me.
I can't even work out what nose weight I should be aiming for?
Do I take a measurement from the caravan (a bailey unicorn Cadiz) or is there something that should have come with the car indicating any limitations of the towbar that is fitted?
I was really good with a cut off broom handle and a set of scales back in the day, so if I knew what to aim for I'd be ok, but I'm pretty lost at the moment.
Car and van being picked up separately in the next 7 to 10 days, so any help greatly appreciated.
Oct 24, 2024
116
64
635
Also from reading other threads, the official figures show I can tow a braked trailer of 2400kg, with the car weighing about 1760kg, but I still feel concerned.
4,371
Without knowing what caravan your intending to tow, we cant really offer any specific advice, except that the caravan industry advise you should not tow a caravan that exceeds the the tow vehicles kerb weight if your experienced, aif you inexperienced you should not exceed 85% of the tow vehicles kerbweight until you gain experience of the outfit.
Nose load should be between 5&7% of the caravans MTPLM but must not exceed the maximum load specified for either the car or the caravan.
Good towing is not just about weights, its about how the car and caravan is loaded and the weight distributed, Heavy items should be kept low down and as close to axle as possible, and adjusted to set the target nose load value.
Driving habits, and being aware of the size of the outfit , and how much time and space is needed to join traffic on the roads etc, and ensuring the car and caravan are fully roadworthy.
Reactions: GaryB
Jan 20, 2023
1,309
1,165
2,435
From memory Volvo specify a maximum nose weight of 110kgs but it will be in your manual. The caravan will probably have a maximum nose load of 100kgs, the lower of the limits is always the maximum. As above, the recommended “ideal” is 5-7% of the caravans maximum weight but without exceeding the limits of the caravan hitch or car Towbar. With your caravan I suspect the 5-7% “ideal” will be over the hitch limit so you’ll be aiming for the hitch limit as an absolute maximum.
Broom handle & scales (on a flat surface) is still a good way to check.
5,315
Thank you. The caravan is a bailey unicorn Cadiz.
What is the year of the caravan? Also year of the car and engine size? The car and caravan weights change over the years? Volvo changed the towbar rating a few years ago and it was lowered. However everything will be in the owner's manual.
Oct 24, 2024
116
64
635
Thanks everyone - and after reading another thread on this, someone put a link to Parkers Guide, where you can input your specific car and caravan, and it will give you a full run down of compatibility.
I don't have the technical ability to put a link to it, but it said the match is perfect, noseweight will be 80kg and my towing ratio for car/ van is 76%.
All the best.
