Hi i need some help. fitted a 80w solar panel to the roof of my van. Also fitted a mppt regulator. Bought a new battery 110 amp to go with the system. used the caravan in the summer and through early wainter and worked really well.
The caravan has been parked up for last 7 weeks and when i checked the volt meter battery was dead. Plugged in the charger and shot to 14v and the green charge light on the solar reg lit up. Removed battery and charged over 2 days and carried out a drop test in work and battery came back ok.
refitted battery to caravan and put meter across and check charge from panel and showing 13.4v. i have checked the van and everything is off. The only item it supplys is the alarm.
The question is only one of those things or has anybody eles had this problem and last but not least any suggestions.
Darren
Darren
