Not sure if any of you folks use these apps but i found them quite useful on our trip away at the weekend.
The first was Stay Level , as the name suggests this app lets you use your and your partners smartphones to aid in leveling the caravan. it works surprisingly well allowing you to set the leveling phone in the van and use the other out side while making adjustments.. Not sure if its cross compatible as we both have iphones.
The other was Antenna Aligner which as the title suggests lets you find the strongest signal to tune your aerial using the gps location on your phone. it then uses a compass bearing and horizontal or vertical alignment to get the best signal.
