A frame bike rack on Bailey unicorn 2016 (or there abouts)caravan
Has anyone any experience of fitting/using the A frame bike racks onto Bailey unicorn ? (1 adult lightweight city bike - Bailey unicorn Madrid, 2016)
Have changed my car and it is unfortunately now an either/or option between carrying bikes on the back or towing 😞 - can’t do both at the same time.
Bike is too big to go in the car, I’m not tall enough & shoulder injury precludes it to go on the roof . Don’t want it inside the ‘van and it can’t go on the back.
The a frame seems the only option:
https://www.agentfiamma.co.uk/fiamma-carry-bike-caravan-xl-a.html
The first thing needed is to remove A frame cover and see if there are any existing holes for fixing that mate up with the carrier, as drilling the frame is a NO. Then consider the weight of the rack plus bike weight added to the towball permitted noseweight. Also will it foul the handbrake operation when a Bike is fitted.
I’ve fitted this carrier to a previous van. No drilling is required other than through the a frame cover if you choose not to remove it (I did)
Weights are well within limits - already checked.
It’s the fouling the handbrake, jockey wheel and other issues I’m after information on, hence posting here.
Try making use of the caravan step to help get it up on the car roof.
As mentioned, Putting something on the roof is not an option even with steps.
Those who’ve said ask someone. All very well until I’m in the countryside with not a person round…. 🤔
There is a roof mounted rack that slides out and down so you load alongside the car then slide the whole caboodle up and across the roof. The bikes lie flat not upright. That would probably suit your needs.
I will try and find a link.
Thanks for he vid, very useful. But unfortunately this isnt an option for me as I can’t lift anything above elbow/waist height
Cost is under £700? However if registered as disabled you do not need to pay VAT! Sadly when you have a mobility issue, you may have no choice except to pay. 🤐
You don't even need to be registered as disabled - if you can genuinely declare a chronic condition then any product which helps that condition can be bought free of VAT.
