It’s actually very hard for a charger to “know” the state of charge of a lithium battery it‘s charging with any accuracy. The voltage across the terminals doesn’t change very much over much of the charge/discharge cycle, Charging the thing to 100 percent is the only real way to establish a known state of charge. Systems can track discharge by monitoring the discharge current over time so once charged to 100 pc a reasonable state is of discharge prediction is possible in such intelligent systems. If the battery is never charged to 100 pc overall discharge logging gets less and less accurate with time as errors compound. Hence I occasionally charge the caravans li ions to 100 pc (at a time when I can use them to take that high voltage top off down ASAP) . Using a Victron battery monitor the charge state display becomes inaccurate over months if you don’t do this. But I don’t leave them at high charge states any more than I have to, time at max voltage ages Li cells,
Steve
