Abbey Advantage Fuses location?
Oct 29, 2023
I can't find my water pump fuse in my 2004 Abbey Advantage. I've checked the wardrobe, by the water pump (where the van external lights are) could it be in this xonsole?
Help!
Nov 30, 2022
942
802
1,135
Tgere are no fuses on those panels, you need to look elsewhere, probably located with the Power Supply Unit, possibly under one of the benches.
Possibly Something like this with a row of fuses visible
1,905
6,935
Hi Gregster and welcome.
No sign of 12-volt fuses there. But they must be somewhere.
Here are the wiring diagrams which seem to show individual fuses, which would be unusual. If they are in line some searching might be needed.
1,905
6,935
Wiring diagrams always show individual fuses, they don't show locations of anything only the schematic layout.
Not always, the diagram in question shows most other items pictorially. So I would expect it to show a 12 volt fuse box in a similar way. But it clearly shows them individually. Which might also be why Gregster cannot find them.
1,905
6,935
Looking again, the OP has an ‘Advantage’ model. Possibly a dealer special. The diagram I pictured above is of the ‘Aventurer’. But the control panel appears the same. The diagrams for other models, Vouge and Spectrum, do show fuse boxes.
3,624
I have a feeling the OPs is one of the older models which had individual in line fuses . Maybe the Abbey Owners Club could help?https://www.google.co.uk/url?sa=t&r...usg=AOvVaw2xgAj0y44cOPmvcYt34-eH&opi=89978449
