Abbey GTS (92) internal trim
As can be seen in the images I have been continuing to replace/repair various internal panels and trims,also the instrument of torture a.k.a THE drawer unit,has been removed,the replacement timber(4mm) thick was obtained from a well known DIY stores,I never met the bees that made the wax.00 origil trim mdf mouldinf_093315.jpg01 ORIGINAL TRIM_093336.jpg02  ORIGINAL TRIM_093407.JPG12 NEW PELMETS RH PULL SWITCH 240V LED _093534.jpg15 NEW PELMETS LH PULL SWITCH 240V LED_093554.jpg10 NEW TRIM_093454.jpg11 NEW TRIM_093516.JPG
A nice looking job, well done.
On of the reasons why the original materials begin to look tired and damage easily , is they were probably cheap and lightweight. I think you would be wise to check the weight of the repaired caravan because your new materials probably weigh more and will change the unladen weight and probably reduce the load margin to the caravans MTPLM.
Prof the materials used are significantly lighter than the original materials,also removal of drawer unit has reduced the overall weight 👍,,MIRO 880kg,MTPLM 1120,,thank you for your comments
