Tried all the suggestions on the weekend and still no water going into the tank changed all valves inside and out there is cold water flowing and back pressure but none to the tank.
As you look at the tank there are 2 pipes coming off the pump and one connecting on the tank. Off the top of the tank red pipe witch connects to the hot water supply. When the taps are turned on the pump kicks in on the bathroom tap but not on the kitchen mixer tap.
As for the gas fire I have now discovered that the pipe has been cut off under the van and I still cant get the blow heaters to work so I would be so pleased if anyone could give me answers to any of these problems
many thanks
helen
many thanks
helen
