- Jun 16, 2020
- 5,902
- 2,808
- 17,935
Bleed valves will look very similar to standard domestic bleed valves. Try following to single pipe circuit heating circuit around the van, you should find up to half a dozen.
Filling is fundamentally the same as filling any heating system and in some ways easier than in a domestic situation as there is only 1 large pipe as opposed to many, possibly down to 8 mm in the domestic. In all cases there is a possibility of an air lock. Alde try to avoid this and speed up the process by using there filler pump, but these are about £400!
I do know of people who have successfully made their own with a submersible pump and force the fluid through the flow pipe.
When I did it on a modern Alde system, I filled it very slowly , not into the header tank but in to the flow pipe by gravity. Then left the pump running at 5 for a short while. Not a lot of bleeding to be done. Which should be done straight after filling then again after running at heat.
It did take me about 4 hours to change the fluid, not cost effective if I was doing it for a living, but that is not the case.
