Aerosol Brake & Clutch Cleaner
May 12, 2006
2,060
Anyone used this to clean out the hitch on the AL-Ko stabiliser ??. Is it the correct stuff for cleaning???
Val & Frank
Hi Frank, I've used this stuff for a few years now. I clean the towball the surface of the pads with firne emery cloth and then spray the ball and up inside the coupling with the aerosol. The brand I use has a nozzle that directs a strong jet to remove particles from the emery and also the carbon from the diesel exhaust.
Jul 15, 2005
2,175
Hi,
Brake cleaner is a 50:50 mix of hydrocarbon solvent (usually heptane) and alcolhol (usually iso-propanol) - the hydrocarbon part does the shifting - the alcohol delays the evaporation time.
It will degrease the tow ball and the pads inside the tow coupling quite nicely.
White spirit is also equally effective, for a fraction of the price, but takes longer to dry.
Neither leave any deposit and are safe on metal and paint finishes.
Robert
May 12, 2006
2,060
Thanks Clive, and you to of course Rob.
I just saw it on the shelf and thought it might do,nice to have it confirmed thanks again.
Val & Frank
46
19,185
I've said before how useful this stuff is for cleaning just about anything, however a word of caution. Being a powerful spray the over spray can go anywhere and I have found it will instantly and permanently mark some painted plastic surfaces it may land on. An example is the household cordless phone, so be careful whats around and about when you use it.
Jul 15, 2005
2,175
Frank,
If you don't wear glasses, it's a good idea to buy and wear a pair of safety spectacles (big, wrap around glasses) from B&Q or another favourite DIY shop.
Aerosol brake cleaner has a strong propellant - and it really jets out of the can - a splash of it in your eye will sting more than a little bit.
Robert
