Air Con
Status
Not open for further replies.
4,389
Perry525 said:
Because cold air drops, homes, offices factories, caravans have their air con units on high, but cars do not. Cars usually have theirs at waist height and the air is blown from vents in he dash board and at floor level.
Would it not be more logical to have caravan air con under the double bed, thereby having the weight low down, avoiding the need for a heavier roof and have it in the space where it is most needed.
Additional weight is rarely wanted or needed in a caravan, most sensible users try to keep touring caravans as light as possible. However if an AC is fitted, it causes less weight related stability problems if its on the floor rather than roof level.
You are correct about optimal operational location being high up rather than low down. Roof mounted units don.t usually need extra ducting to distribute the cooled air. Also they can get away with lower pressure fans and might be quieter, where as floor mounted ones do need ducting, so not only the additional weight but the ducting also needs to have space allowed, and it isn't always easy to route it ideally. You need a higher pressure fawn to blow teh air along ducts so its likely to be noisier.
There are many detail differences between cars and caravans which will affect the ultimate performance, but essentially cars will always have more mechanical power available to drive the AC compared to the power available in a caravan. yet cars have a much smaller habitation volume so the system most people are now used to is far more powerful than any system that can be fitted to a touring caravan, yet the caravan has a far bigger volume, and indeed surface area to collect solar heat energy, so the AC has mighty task on its hands. These are some of the reasons that caravanners who have AC fitted may have great expectations but the reality is often disappointing. Most will says its not a total waste but it will never have the same impact as AC in cars.
Hutch has mentioned water evaporative coolers. There basically raise the humidity of the air in the caravan. They work well initially, but as time goes by the air becomes saturated and cant take up any more evaporated moisture. so they become less effective the longer they are used. Also the water vapour tends to be absorbed by soft furnishings and wood so if you have a cooler night you are more likely to get extensive condensation the following morning. The raised humidity with temperature is also a better breeding ground for microbes. I have seen what they can do to someone with lung problems.
5,362
Our air con is fitted on the roof and weighs about 32kg. Even on full blast you can hardly hear it outside however we very seldom need it going full blast. Bonus is that it will also de-humidfy the air inside the caravan if required. In winter we have the facility to use it for heating.
We would not be without an air con. Helps our long hair dogs keep cool during the summer when the temperature is high. A real blessing when in France or Spain.
9,285
Our Springers used to make for the underneath of the van when it got very hot in southern France.
5,362
@Buckman, I appreciate this post is 2 years old, but wondered what kind have you got and what amps does it need to run? I (used to !!) go to France a lot but the sites would often only have 6 amp ehu.
Have got a portable one (https://www.electriq.co.uk/p/compact/electriq-compact-air-conditioner) , which is ok, but takes up space and quite noisy, but helped keep the dogs cool.
We had the Dometic Freshjet 2200, but last year in August it was replaced with the Truma Avente Comfort at a cost just under £1500 as the Dometic gave up the ghost. We think it is worth every penny.
Unfortunately we have not been able to go to France or Spain since it was installed, but it has worked well here in the brief couple of summer days we had last month! :D
Reactions: fkeates
Apr 8, 2019
47
27
10,535
Thanks, I've just posted a new thread as this one's old. Which would you recommend and what amps do they need?
Like you, no trip abroad last year nor this, but fingers crossed for next year 🌞🤞😙
Status
