ALDE FAULT ON PANEL THIS MORNING
Morning all,
I woke to no heating this morning , overheating red fail on panel.
Any ideas or is an eng required?
Thanks once more πŸ‘
The book says
Air trapped in the system
Fluid level too low
Fluid mixture too weak or strong
Circulation pump not working
Sensor defective
12v supply not stable
Cheers , i have a feeling its air and mixture strength , going to book my service early and get heating done at same time.
Previous owner just said they topped up when required but i am unsure if they used neat fluid.
Thanks.
I had a similar message recently. My battery had gone flat overnight. . After turning off the 12volt supply and charging the battery the message disappeared (after resetting the heating control to reset). . Two weeks later my battery overheated (while we were away in the caravan on electric hookup) . So the battery was on it's last legs.
