- Jun 9, 2023
- 45
- 46
- 1,535
So my Alde heating system has a problem.
Works fine on Gas. Hot water immerser switch provides plenty.
Problems is that when I try to set heating to run on Electric only, it doesn't heat up.
Not on 1kW - 3kW. I know electric isn't that great but even after 4-5 hrs its still cold.
I can hear the pump running and the tank in cupboard gurgles away and has sufficient fluid in it.
I have bled both the bathroom rad and the one at the door. They both run really hot on gas heating.
Visited dealer where I bought van, second hand, from and its either an element issue, which will require a return of whole unit it ALDE.
Or it could be a PCB issue. They would need a check to see what, if any, the the current draw was on 1kW, 2kW and 3kW.
Just looking for some useful info and possible things I can check.
They suggested the cost to replace the PCB would be around £400.
Bailey Unicorn Madrid 2011
Thanks for any ideas.
