Alko jacking brackets
Dec 27, 2022
581
420
2,135
What did I do wrong, or are they made of cheese?
Arrived at van, Elddis 554, to check it over and found a flat tyre, it has a duff valve.
The surface underneath the van is scalpings so coarse but loose surface.
Removed the spare from its holder.
Steadys were down, handbrake on, I chocked the other wheel. Loosened wheel nuts, jacked the van up using Alko side jack, removed the wheel.
Now we come to the exciting bit.
As I was fitting the spare I felt the van move and the spare was then jammed in the wheel arch. Jacking bracket bent at 45deg.
Panic ensued, step son arrived with trolly jack, I then jacked the van back up and fitted the wheel.
I feel perhaps I should have wound the steadies down after jacking the first time but they were wound down before the tyre went flat so should have been tight.
Oh and it started to pour with rain halfway through ☔
My dilemma is now do I fit the same again just on the one side or do I go for the uprated ones from a breakers at double the cost and do both sides.
Part of me says just leave it and call the breakdown services if I ever need to change a wheel.
9,141
I would have put some blocks around nosewheel or hitched to car. Plus as I started to lift I would raise the opposite steadies and lower those on my side. Keep doing it incrementally until the wheel is removed. Then do the reverse on the way down. Jack base would have been positioned on a hard poly chopping board to spread the weight.
PS edit. I always used sidelift plus L shaped brackets when I stopped carrying a trolley jack around. Even used side lift in storage or on drive.
Reactions: West Riding lad
Dec 27, 2022
581
420
2,135
Some points.
I don't think the breakdown covers it when in storage and not attached to the car.
It faces an 8ft bund, goes in and out on the mover so no chance of getting the car into the 2ft gap at the front.
Still I've ordered some reinforced points as the 2x800kg is a bit close to the 1600kg* that the van is when in storage.
* 1500kg when on the move.
4,591
The old lightweight brackets are well known to bend over, I think Dusty Dog has a photo. There is an Uprated type. I bought a KoJack scissor jack and brackets, much stronger. My present caravan has the heavy weight Alko brackets which are identical to the KoJack ones.
AlKo
5,290
Some points.
Mayday covered ours when in storage and not attached to the car. No issue.
4,591
We would have called the breakdown company as after all, that is why we are paying them.
I would rather change the wheel myself, rather than wait a couple of hours, but if health issues dictate, otherwise , that fine.
9,141
The RAC have been getting some bad press recently. One 80 year old leaving hospital after cancer treatment phoned for assistance late morning. In the end by mid afternoon he got a Uber home, his wife followed home around 6pm and left car at hospital. Next day she was offered a six hour time window, but by then her son had driven over and resolved the problem. Another one was a mum and child left for hours in a dark industrial area.
Our granddaughter had a puncture on a construction site she was visiting near to Llandovery and was told it would be several hours before assistance would attend. As the site was closing at 5pm and no further updates from the RAC one of the workers fixed her tyre with a noodle plug and it held pressure and no leakage so she drove home. Similarly she had an exhaust failure out there on a remote road and attendance was going to be some hours. When the agent did attend three hours later he removed the failed end box and she drove home.
The common thread here being that all the incidents involved elderly and/ or vulnerable people in less than ideal areas.
4,591
Fred Drift,
When I had to call Mayday in the summer, to get my car home , due to a locked on Electronic hand break, the recovery truck had to come 20 miles from Northampton to Toddington, in Bedfordshire, 2 1/2, hours before he got to us, as he wouldn't come down the M1, during rush hour.
5,290
Never had to wait hours and generally only about 30-45 minutes. Only time we had to wait hours was when the car broke down and they needed a low loader.
4,591
That is what I required, a low loader, obviously Mayday don't have their own, fleet of them and contract out.
I will start a new thread, rather than Hijack this one.
1,350
855
1,435
Fred Drift,
Fred can't resist 😆
  • Haha
