- Dec 27, 2022
- 710
- 493
- 5,135
What did I do wrong, or are they made of cheese?
Arrived at van, Elddis 554, to check it over and found a flat tyre, it has a duff valve.
The surface underneath the van is scalpings so coarse but loose surface.
Removed the spare from its holder.
Steadys were down, handbrake on, I chocked the other wheel. Loosened wheel nuts, jacked the van up using Alko side jack, removed the wheel.
Now we come to the exciting bit.
As I was fitting the spare I felt the van move and the spare was then jammed in the wheel arch. Jacking bracket bent at 45deg.
Panic ensued, step son arrived with trolly jack, I then jacked the van back up and fitted the wheel.
I feel perhaps I should have wound the steadies down after jacking the first time but they were wound down before the tyre went flat so should have been tight.
Oh and it started to pour with rain halfway through ☔
My dilemma is now do I fit the same again just on the one side or do I go for the uprated ones from a breakers at double the cost and do both sides.
Part of me says just leave it and call the breakdown services if I ever need to change a wheel.
