It's an easy enough job if you are a reasonably confident DIY'er.
If you are at all uncertain then any AWS engineer should be able to do the job for you in 30 minutes (or less)
Why do you want to change them? If they are "groaning" then give them a good rub down with some fine emery cloth or wet and dry, to break the "glaze" that can occur.
Try YouTube there are many videos availableI had an issue with the Alko disengaging whilst towing, handle would raise leading to serious wobbles….. and near heart attacks! Pads were worn, after only two years. Albeit we have towed many many miles in those two years. Just had them changed by a professional but would like to know how to do it myself. So no groaning or creaking, from the van or towball but lots from me!
Was that for two or four pads?OH and I are rubbish at diy and such like, but even we managed to change the pads via a you tube video. It was just an out and in as far as I remember. Give it a go, good luck
The side pads need only a small flat blades screwdriver to remove and replace. The front and aft pads need a torxs screwdriver to replace them.Was that for two or four pads?
Four, if I remember correctly. It was quite a while ago.Was that for two or four pads?
I would still check that fact myself first !!My 'van is in for a service, just been told mine need replacing. I will do it myself though.
I wouldn’t use a flat blade screwdriver, perhaps a philips or even a flat drift for the side pads as the flat blade can damage the ‘O’ ringsThe side pads need only a small flat blades screwdriver to remove and replace. The front and aft pads need a torxs screwdriver to replace them.
Just remember that the Alko friction pads are there to help reduce snaking. They should not be relied upon and certainly no substitute for correct loading and general caravan setup.I had an issue with the Alko disengaging whilst towing, handle would raise leading to serious wobbles….. and near heart attacks! Pads were worn, after only two years. Albeit we have towed many many miles in those two years. Just had them changed by a professional but would like to know how to do it myself. So no groaning or creaking, from the van or towball but lots from me!
He said, whilst pushing his glasses back up the bridge of his nose with his forefinger 🤣Just remember that the Alko friction pads are there to help reduce snaking. They should not be relied upon and certainly no substitute for correct loading and general caravan setup.
That’s almost like what I said 🤔🥴You can change the side pads using just a small flat bladed screwdriver. But I wouldn't.
