Alko pads
Nov 30, 2022
2,015
1,916
It's an easy enough job if you are a reasonably confident DIY'er.
If you are at all uncertain then any AWS engineer should be able to do the job for you in 30 minutes (or less)
Why do you want to change them? If they are "groaning" then give them a good rub down with some fine emery cloth or wet and dry, to break the "glaze" that can occur.
Reactions: Mark1962
JRT
May 5, 2024
271
180
235
Agreed, and the ball on the car too. I find most groaning and creaking can be eliminated by giving the tow ball a clean.
Jan 20, 2022
53
30
4,585
I had an issue with the Alko disengaging whilst towing, handle would raise leading to serious wobbles….. and near heart attacks! Pads were worn, after only two years. Albeit we have towed many many miles in those two years. Just had them changed by a professional but would like to know how to do it myself. So no groaning or creaking, from the van or towball but lots from me!
9,558
Try YouTube there are many videos available
2,352
OH and I are rubbish at diy and such like, but even we managed to change the pads via a you tube video. It was just an out and in as far as I remember. Give it a go, good luck
5,504
Was that for two or four pads?
Nov 30, 2022
2,015
1,916
If you look on Alko's website there is a diagram that shows how to gauge how worn your side pads are. No point in replacing them if it's not necessary as they ain't cheap items.
Reactions: Mark1962
5,538
The side pads are secured by hidden internal o rings. Make sure you replace them at the same time. They hold the pads in the correct position moving with the red lever
Reactions: Mark1962 and Hutch
JRT
May 5, 2024
271
180
235
My 'van is in for a service, just been told mine need replacing. I will do it myself though.
Jun 6, 2006
1,034
253
The side pads need only a small flat blades screwdriver to remove and replace. The front and aft pads need a torxs screwdriver to replace them.
I wouldn’t use a flat blade screwdriver, perhaps a philips or even a flat drift for the side pads as the flat blade can damage the ‘O’ rings
Reactions: Dustydog and Hutch
May 10, 2020
320
220
10,935
Just remember that the Alko friction pads are there to help reduce snaking. They should not be relied upon and certainly no substitute for correct loading and general caravan setup.
Reactions: borderbilly
Nov 30, 2022
2,015
1,916
Fair enough, but not all dealers are so honest and trustworthy, hence my suggestion to chrck.
53
30
4,585
He said, whilst pushing his glasses back up the bridge of his nose with his forefinger 🤣
  • Haha
Reactions: Hutch and JRT
4,800
You can change the side pads using just a small flat bladed screwdriver. But I wouldn't.
Dec 27, 2022
710
493
5,135
I have a set of parallel pin punches like THIS one of which fits the hole to push the pads out.
Mine are left over from work but cheap enough to buy.
