Alko tow hitch
Aug 16, 2009
Hi I have a sterling europa caravan with an alco tow hitch is it normal for these tow hiches to creek and grown when traveling round tight corners eg trafic islands or reversing.I keep the towball grease free, is that correct
Jun 6, 2006
801
134
18,935
The creaking can be down to a couple of things, one could be lack of grease on the hitch assembly and the other could be down to contaminated friction pads, you can clean the pads with some wet and dry abrasive paper and then spray break/clutch cleaner on the pads to get rid of the particles
Dec 7, 2006
201
Hi, had the same problem. Dealership said it was bedding in. Bull! I finally discovered I had a standard towball and not the long necked ALKO one needed. Check which one yuu have. Cost me less than a tenner to replace it,
Homer
Aug 16, 2009
Homer
hi many thanks will check to make sure its the correct towball
Sep 21, 2007
258
16
18,685
Hi Peter
Assuming there are no loose bolts on your tow bar or stabiliser head and you have the correct tow ball fitted as Homer suggested then-
the tow ball should be spotless, no paint, no grease, no rust etc...
The stabiliser pads should be clean also. I found rubbing some very fine wet'n'dry paper over them and then cleaning with brake cleaner, available from motor accessory shops, helped.
With the van unhitched and the stabiliser lever pushed down you can feel the pads either side of the head.
I still get a slight noise sometimes but that seems to be the norm.
Mike
