alloy wheel torque settings?
May 19, 2021
42
27
35
2018 Swift Europa 590 TD with alloy wheels, can anybody advise correct torque settings in Newton meters Sadly not on Caravan plate
Jan 8, 2006
264
6
18,685
130Nm for Alloys - probably 110Nm for locking wheel nuts/bolts if you have them. 88Nm for Steel spare wheels.
I discovered some years ago when changing a wheel due to a puncture that you need shorter wheel studs for your steel spare. That is why there should be extra short studs in your caravan when you buy it. Green Flag discovered this on the M5 and I had them in my box of bits.
4,672
Now thats interesting, my Coachman doesnt have any spare bolts and says nothing about changing bolts for alloy wheel to steel spare tyre.
9,331
Neither did my Swift Sprite for its steel spare wheel. Just a difference in torques. Cars have same bolts too for steel space savers.
Oct 17, 2010
1,321
567
Dose not apply. My motor and Swift Challenger use the same bolts for Alloy and Steel spare.
May 10, 2020
318
220
10,935
Just a point to make about torque settings. Please be aware that contamination on the threads of the studs or brake drum holes , be that grease, rust or dirt, can and will effect torquing up. I know some people insist on slapping copper slip on the studs….well DONT.
Reactions: DaveA1
