Another newbie needing towing weight advice sorry!
Oct 24, 2024
Hi all and thanks for your help in advance,
We attended the caravan & motorhome show at the NEC over the weekend and were really excited to put down a deposit for a family caravan.
The caravan is an Elddis Crusader Zephyr 2024 model with a MTPLM (kg): 1,890 & MiRO (kg): 1,731.
Our intentions are to tow with a Citreon Dispatch 1000 Enterprise Bhdi 2019 van and the general vibe at the show from the various salesman I spoke to was that because it was a commercial van this shouldn't be an issue (the "Technical permissible maximum towable mass of trailer" "braked" weight in the V5 document is 2,000 KG)
However.... I then started reading a bit more into it and having looked at the VIN details and "Mass in service" weight on the V5 (1,597 KG) i am now incredibly nervous we have messed up and I could end up having to cancel my order which would be really upsetting :-(
The VIN details are below;
Line 1 = 2,640 KG
Line 2 = 4,040 KG
Line 3 = 1,500 KG
Line 4 = 1,500 KG
I hope somebody can help and please let me know if you need any more details.
2,449
Your VIN details show a basic towing limit of 1400 kg - BUT - you could increase it by not loading the van fully - since the van's payload is 1043 kg (2640-1597) that's quite possible depending on how you use/load the van.
Traditional wisdom is to limit towing to 85% of kerbweight for beginners so that would be 1597 x 0.85 = 1357 kg
Oct 24, 2024
Hi Roger,
Thanks for coming back to me, so basically if the Caravan's MiRO is 1,731 KG, going on the traditional wisdom weight ratio for beginners I am 1,731 - 1,357 = 374 KG in the no-go zone before anything is even put into the caravan with an empty van?
The plan was to use the van/caravan for exhibiting at shows, so the van at a rough guess could be loaded with anything from around 300-400 KG in stock/equipment and then between 120-180 KG in humans.
Aug 24, 2021
242
252
4,835
The problem with the shows is that most of the salesmen are anything but experts in their field. The large dealerships employ them for the duration of the exhibition . This week it's caravans and motorhomes, next week it's somewhere else with kitchen equipment or furnature.
I well remember a good number of years ago meeting a family of four on a Caravan Club (as it was in those days ) site with a brand new siv berth Ace tourer which they had ordered at that year's show.
They wre traumatised by the tow there in their VW Beetle 1300 and were dreading the return home !
The 'salesman' had assured them that the car would have no trouble handling the 'van.
ALWAYS carry out your own independent research before signing that order form !
Aug 12, 2023
532
226
1,135
Sales brochures says 100 towing limit is 1400kg braked, 120hp version is 2500kg. Nowhere was there any info on drivetrain ie FWD or RWD. Any caravan of that size I'd say RWD minimum ideally AWD.
764
lutzschelisch.wix.com
To make full use of the car's V5 towing limit of 2000kg you wouldn't be able to load the car up to more than 2040kg withput exceeding legal limits. That's 600kg less than the GVW. If the car's mass in service is 1597kg that would mean that you would only be able to put another 443kg payload in the car, including the noseweight of the caravan.
It's not an ideal combination and you will definitely be exceeding the 85% weight ratio recommendation quite considerably. In fact it will be over 100% which is about the maximum that one should stick to and more than some insurance companies will allow.
764
Birty, use this site, Parkers to find your exact car with weights. This will be a help for yourself.
NEVER use any database to gather exact information. Such details can only be used as a rough indication, but no more than that. If you want definitive details you must refer to the vehicle's weight plate. For kerbweight, etc. which is not shown on the weight plate, go to a weighbridge and have it weighed.
3,480
It can be a useful site, rather than just relying on people on forums for information, they should NEVER, be relied on 100%.
Oct 24, 2024
Thanks all I really appreciate your responses, unfortunately though I'm still a bit unsure on how I should move forward with this one...
I think (if I am understanding this correctly) the van mechanically (and possibly legally?) should be able to tow the caravan (this is based on the V5s figure of 2,000 KG, and the Caravans MTPLM of 1,890 KG, however... if I'm driving the van empty, based on towing recommendations/VIN figures I shouldn't really be towing anything more than 1,357 KG - it will be unsafe, unstable and overall just a hazard to my family and other people on the road.
If I load the back of the van with approximately 400 KG I could make the figures look a bit healthier and make the journey a bit more comfortable/stable but this could be a headache/worry all the time...? i.e. I would like to think we would sell stock at exhibitions so we could be travelling home from a show with a much lighter payload for example.
So does this mean I probably should be thinking very carefully about cancelling the caravan? Guess that means I could now end up in a battle with the dealer to try and get my deposit of £2,000 back :-(
3,480
You will never, really be towing a caravan, with a totally empty " Van" their will be some basic equipment and probably a passenger. Remember another 35 kg for a towbar.
The 85 % "rule, is very outdated, and although a good thing years ago, how long does it take to become a competent tower.
Somebody that does 200 miles each way 3 times a year, for 5 years or someone going away doing 100 miles each way every second weekend for 9 months.
I think your best option, in my opinion, would be to go back and negotiate with the dealer for a lighter caravan.
Good luck.
764
Whether the outfit is unsafe, unstable or a hazard to the family and other road users is up to you, not the caravan, but the lighter it is, the easier it will be for you to ensure a safe tow.
By the way, the weight ratio recommendation is based on kerbweight, not V5 mass in service. Not so very long ago on another forum, a difference of over 230kg was reported between mass in service and the vehicle's actual weight (which is, by defintion, close to kerbweight) and that was even documented as such by the vehicle manufacturer.
