Any owners of Lunar Lexon 640s out there (2004)?
Aug 4, 2004
4,343
I am a little concerned about the height of my awning rail from the ground up. Mine is at about 230 cms whereas Lunar say it should be about 230 -250 cms. Unfortunately they cannot be specific on this as they only measure the overall height of the caravan to the top of the Status aerial. If you have a similar caravan or even a EW, it would be appreciated if you could check your height and advise if it falls into the correct parameters.
Aug 4, 2004
4,343
Sorry, that should read 250 cm to 280 in height for awning rail as per Lunar specifications.
(I wish we could edit our postings after it has been posted!)
Apr 6, 2009
8
Hi Ian
My lexon 640 is 2350 from ground to awning rail centre and I use a Bradcott awning on the van as my big one and also use weekend porch type both work no problem with no height issues...just cae accross your post and went and measured van ....lol....hope this helps you when and if you see this.
